Results 1 to 13 of 13
    2- 2.5 200 and 200PM power heads.
    Everything is sold except for below!
    Drilled straight leg Hi-Perf saddle, 2pc PM plate with new Bob’s tuner hoses and pump.
    2- 2pc plate MM complete wing plates, tilt pins and rams.
    Tony
    516 807-1456
  2. Likes Frank Molé, tunnelmike liked this post
    Jan 2020
    Pinole, Ca
    You have any bare blocks? Or would you be willing to sell one without all the EFI components?
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
    No, I do not have any bare blocks and hate to break them down.
    You can sell the complete EFI setup, they are all fully serviced and ECU's are checked out.
    Things left....10/14/20
    A very clean straight leg mid sections, Hi-Perf late style single ram saddles, 2.5 2pc plate, wide exhaust ports, solid mounts, drilled cans, 1/2" tiller bolts, with new Bob's tuners.....$950.
    1- clean, serviced LH, straight skeg, 1:87, 4 hole, wide passage CLE.....SOLD
    1- clean empty straight skeg, 4 hole, wide passage, CLE bare aluminum....SOLD
    1- clean cowling Top & Pan with SS pan plate...NO skirt..........SOLD
    ***I have trim pumps and OEM hoses if needed it.
    ***set of 2pc plate side steering MM plates (in picture)....$400 for set.
  6. Likes Frank Molé liked this post
    Dec 2011
    united states
    Tony, do you have any factory 1pc plates for a promax? Or Any alien cowlings, RH lowers swept skeg? Hope all is well! I gave you a shout yesterday might be looking for some miscellaneous things as well.
    All the best,
    Cory
    Quote Originally Posted by Coryc View Post
    All the best,
    Cory
    Hi Cory, got your VM just busy day, on my list to call you today but will respond here incase anyone else has the same questions.
    No, I do not have any 1pc plates, Alien cowlings or RH HiPerf cases left. Only stock 2.5 and 3.0L.
    Regards,
    Tony
    Sep 2020
    Bermuda
    Is this complete 2.5 200 still available?
    Quote Originally Posted by Quari00 View Post
    Sorry all motors are sold
    Tony
    Below is what I have left 10/11/20
    I have a very clean straight leg mid sections, Hi-Perf late style single ram saddles, 2.5 2pc plate, wide exhaust ports, solid mounts, drilled cans, 1/2" tiller bolts, with new Bob's tuners.....$950 each.
    A very clean, serviced LH, straight skeg, 1:87, 4 hole, wide passage CLE.....$1200...NOTE; The skeg looks short but is not, it's just the picture
    A set of 2pc plate side steering MM plates (in picture)....$400 for set.
    Aug 2009
    mich.
    hello interested in lower
    Aug 2009
    mich.
    interested in lower
  14. #12
    Quote Originally Posted by groock View Post
    interested in lower
    Yes, I still have it and to be clear it's a LH 1:87 straight skeg case.
    Got your PM and responded.
    Tony
    516 807 1456
  15. #13
    CLE is SOLD
  1. Power Heads?
    By lancer in forum Technical Discussion
    Last Post: 07-18-2010, 04:43 PM
