Results 1 to 1 of 1
06-12-2020, 12:26 AM #15000 RPM
- Jun 2006
- Ramona Ca
- 270
Brass collard impeller or composite impeller
Trying to see if there is a difference between the brass collard water pump impellers, to the ones with the composite. I have been told I can run the composite style, but wanted to get your guys input. Thanks. I have it on twin 280’s.
Mercury Tech: Factory Merc impeller with plastic insert instead of brass?
By Forkin' Crazy in forum Technical DiscussionReplies: 12Last Post: 07-16-2018, 09:25 AM -
Impeller
By convincor in forum Technical DiscussionReplies: 3Last Post: 03-08-2018, 06:40 PM -
Mercury Tech: impeller
By pool boy in forum Technical DiscussionReplies: 2Last Post: 04-17-2009, 04:37 PM -
run dry Impeller
By Stealth Assassin in forum Technical DiscussionReplies: 6Last Post: 05-05-2007, 06:57 PM -
Impeller
By Chummy in forum Technical DiscussionReplies: 4Last Post: 06-16-2002, 10:51 PM
