Results 16 to 30 of 37
    Sep 2017
    Ashland city tn
    I know mark knows his props with bassboats and I'm not gonna question it (much) , but he tells me I'll get more bow lift with a 3 blade than the trophy , I always thought 4 blade lifted better?
  2. #17
    Bolt on that tempest. You will see what it does.
  3. Thanks Merc 2.5 thanked for this post
  4. #18
    Sep 2017
    Ashland city tn
    Made 2 very quick passes with the tempest and at 1st with the high prop to pad , it was actually little worse , I decided to lower my jackplate all the way which prob 2in or so below pad and carried the boat like its suppose to. What I haven't tried is runnin my trophy at the same level I just run tempest , I'll prob end up gettin a tempest but gonna try trophy 1 more time and see what I get ,
  5. #19
    Sep 2017
    Ashland city tn
    Just gonna rant a second
    I was on bbc tryin talk to a guy bout a tempest he had and the all mighty deleted all my post and sent a message sayin I had to have my last name and bunch **** in my profile , well I'm damn sure not gonna give u directions to my house. Damn ! Gets aggravating, people let any kinda power go straight to their already bowed up head. Anyway.
    I'm think a b&b tempest is gonna be my ticket , still got another test to do, but I've bout made up my mind
    Xstream said while back in another post , that tempest dont get the credit they deserve and that was some proof I had today , I've never had my boat chine walk up in mid 70s , but it started to walk and started feeling light on top. Exactly what I was looking for , but will need me modded sum so I can run it as high as I want. I was impressed
  6. #20
    Sep 2017
    Ashland city tn
    I thought I had my trophy traded but fell thru , so I told mark how tempest did and what I needed , he seems confident he can help my prop , so I got it sent off today, hopefully it performs like I want it to
  7. #21
    Sep 2017
    Ashland city tn
    Well I feel like a moron , I had my setup just all wrong
    I sent my trophy off , so I put on my stock 28 chopper and went tested , and I got plenty of bow lift now , ran this one up to 5800 5900 round 75-78mph , so I came home and got my modified 28 chopper which I can spin usually 300or so rpm more , gonna go try it in few. Cant believe I was just so wrong on my setup. Got my steering adjusted and its ridin on pad like it never has
  8. #22
    Bet the tempest still outruns the chopper, and will have a better, more solid hookup all the way thru the range.
  9. Likes LakeFever liked this post
  10. #23
    Sep 2017
    Ashland city tn
    Still havent got a tempest , hopefully he will work wonders on the trophy , its gettin the whole 9 yards , but I'm tickled to see this thing finally acting right
  11. #24
    It's surprising to see the change just a little tweak can make.
    Jun 2018
    Floating around
    I just bought a 27 tempest but so far my 26 chopper with extra cup is my fav. Havent run a trophy yet.
    Merc 2.5 what was wrong with the set up?
  13. #26
    Sep 2017
    Ashland city tn
    Well kinda long story , as I was just getting into the speed thing then. I had a small bass boat 15ft actually measure 14.9. but I ended up with 200 and hydro jackplate , that boat needed alot of engine height cause stern sit sooo deep , when I went to the 19.6 ft , i was tryin run that same jackplate height and i had my motor mounted high as possible on the plate , which had me way up there but the boat is to heavy for that , I lowered motor on the plate and ran plate bottomed out and worked up very little at time til I got it where boat liked it. I just had it in my head that I gotta run even with pad to get speed but was killin my lift. I was just a hard headed ,dumb mistake. I wish boat was bout 300lbs lighter and b perfect bass rig. I'll get the cmate finished up soon enuff so I can go fast , which high 70s 80 is movin pretty good for big fishin load. Would like to see it hit low 80s with new prop work comin
  14. #27
    Sep 2017
    Ashland city tn
    I remember when I could take a prop to the local guy b4 he closed (not that long ago) and u could get a new hub pressed in and extra cup added etc for bout 150 -200$ well them days long long gone I guess, balance and blueprint and cup for bowlift over 300$ I like to chit myself
  15. #28
    If they are using digital tools somebody has to pay for it. Old days they beat them on a wood pitch block and called it good.
    Sep 2017
    Ashland city tn
    I sure hope it is digital. Dont think it could b blueprinted without it really , how the times have changed and I'm not that dang old
    I'll be sure to post a pic to get opinions on it
  17. #30
    My prop guy would give a digital points readout of before and after any work. It looked like a "map grid " of the prop at many different points across the blades. He fell into the dope scene.....Don't know where he is now. Damn shame, he was very talented and could tweak a prop better than anyone I ever knew. His props were smooth runners, and hooked well.
  1. WTB - Trophy or Trophy Plus 24P prop
    By motuman in forum Propellers Wanted
    Last Post: 06-05-2019, 12:04 PM
  2. Merc prop id from serial number. Trophy or Trophy Plus?
    By Mr. Demeanor in forum Props, Setup, and Rigging
    Last Post: 08-07-2016, 12:26 PM
  3. What is the difference in Trophy vs Trophy Plus props?
    By ssv1761982 in forum General Boating Discussion
    Last Post: 12-05-2010, 06:07 PM
  4. Going from a 21 laser 2 to a trophy what pitch on the trophy?
    By 18'baja in forum Props, Setup, and Rigging
    Last Post: 06-21-2005, 06:11 AM
  5. Wayne,article on Boger re-worked Trophy
    By 22VelocityProMax300 in forum General Boating Discussion
    Last Post: 10-26-2001, 08:56 PM
