Results 1 to 5 of 5
    jonesville, La
    225 promax bogging
    Motor Boggs sometime when you crank it up and wont rev right, checked replaced stator, checked switch boxes, cleaned injectors, new fuel pump Nd pressure is correct and holding steady, changed computer and harness, and still Boggs, but turn off key and crank back up and will run perfect as long as you dont shut it off, does this about 70% of the time, reeds are fine also, crank and it Boggs, turn it off crank back up blip the throttle if it revs it's good to go, if not shut off and repeat until it's right, 2-3 times before its good?
    jonesville, La
    Any ideas
    Houston, TX
    Is it a definite bog or is it a miss?
    Sep 2017
    Ashland city tn
    Have u checked the fire when it dont wanna rev?
    jonesville, La
    No It doesn't miss or stumble, just Boggs, shut it off and crank again. Runs great, I think it might be the TPS now that we've thought about it , does the same with either box and harness
  1. v4 bogging at low end
    By delawarerick in forum Technical Discussion
    Last Post: 09-19-2018, 06:12 PM
  2. Mercury Tech: Pro Max bogging??
    By Vinnie in forum Technical Discussion
    Last Post: 06-09-2009, 12:42 PM
  3. still bogging
    By gambler2663 in forum Technical Discussion
    Last Post: 06-06-2008, 08:15 PM
  4. 250 EFI bogging
    Last Post: 06-01-2008, 06:55 PM
  5. Bogging xp 150
    By Richie R in forum Technical Discussion
    Last Post: 08-17-2006, 02:22 PM
