Results 1 to 5 of 5
Thread: 225 promax bogging
06-06-2020, 10:57 AM #15000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
225 promax bogging
Motor Boggs sometime when you crank it up and wont rev right, checked replaced stator, checked switch boxes, cleaned injectors, new fuel pump Nd pressure is correct and holding steady, changed computer and harness, and still Boggs, but turn off key and crank back up and will run perfect as long as you dont shut it off, does this about 70% of the time, reeds are fine also, crank and it Boggs, turn it off crank back up blip the throttle if it revs it's good to go, if not shut off and repeat until it's right, 2-3 times before its good?
06-07-2020, 06:26 PM #25000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Any ideas
06-07-2020, 11:06 PM #3
Is it a definite bog or is it a miss?
06-08-2020, 05:46 AM #4
Have u checked the fire when it dont wanna rev?
06-08-2020, 07:12 AM #55000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
No It doesn't miss or stumble, just Boggs, shut it off and crank again. Runs great, I think it might be the TPS now that we've thought about it , does the same with either box and harness
v4 bogging at low end
By delawarerick in forum Technical DiscussionReplies: 14Last Post: 09-19-2018, 06:12 PM -
Mercury Tech: Pro Max bogging??
By Vinnie in forum Technical DiscussionReplies: 10Last Post: 06-09-2009, 12:42 PM -
still bogging
By gambler2663 in forum Technical DiscussionReplies: 5Last Post: 06-06-2008, 08:15 PM -
250 EFI bogging
By gambler2663 in forum Technical DiscussionReplies: 2Last Post: 06-01-2008, 06:55 PM -
Bogging xp 150
By Richie R in forum Technical DiscussionReplies: 6Last Post: 08-17-2006, 02:22 PM
