Results 16 to 30 of 35
    Norway
    Hi!
    Straight V no steps no pad Classical offshore race hull, fairly fast too
    Cheeers, Toffen
  2. Likes David liked this post
  3. #17
    that works...
  4. Likes XstreamVking liked this post
  5. #18
    Illinois
    Why can't your have both a pad and steps. Fountain Powerboats have been doing it for years.
  6. #19
    Pekin, IL
    Like my pads. I have owned several STV and have always gone back to Allisons or Hydrostreams. Wouldn't know a stepped bottom if it bit me on the leg.
    Rock
    Team Junk
  7. Likes keefallan liked this post
  8. #20
    Nov 2020
    New Zealand
    The easiest option is to as mentioned already just to convert the round bottom to a Vee and sharpen up the strakes so they dont look like they are fashioned from Plasticine.
    However the question on my mine is why didn't the guys who designed the Sidewinder do this in the first place?
    I know this round bottom Vee design was common in the 1970's.
    Would a Vee conversion at 19 deg deadrise on a Sidewinder still chine walk? and being a relatively simple conversion one would expect that a few Sidewinders/Panthers would have been converted here in NZ where we love to tinker but Ive never seen one with a conversion.
    They also tend Porpoise in hard turns which I suspect is due to the forward Chines.
    The Strakes also curve in toward the keel at the bow so one of the first jobs will be to fill in the forward Strakes on the inside so they can be ground off and re-positioned from the outside once the Hull is flipped over.
  9. #21
    Lake Coochiching, Ontario
    Did the Sidewinder bottom pre-date the invention of the pad? It pre dated V6 power, which increased the need for a pad
  10. #22
    No it just was designed to go 45mph.
  11. Thanks XstreamVking thanked for this post
    Likes tlwjkw, NZ Sidewinder liked this post
  12. #23
    I run pad bottoms. Vents are ok but very tricky to get right. I concentrate on giving the hull adequate bow lift using the strakes without having to use much if any positive trim. That combo has always worked well for me. No porpoise and no china wok. Just a linear thrust with everything lined up.
  13. Likes loop liked this post
  14. #24
    Jun 2004
    Alva Fl
    Quote Originally Posted by Brad Zastrow View Post
    Ha,Ha,Ha,a beat me to it..owned 5 loved them all. Best of both worlds pads and steps. Reggie knew how to make them work.
  15. #25
    Sep 2011
    maryland
    I'm just for a boat...........I dont care if its got steps, ladders, or stairs!!
  16. Likes InjectorService, XstreamVking liked this post
  17. #26
    Dec 2001
    HeeHee......I fell down some stairs.......missed my stepp......not going up a darn ladder............You know this.....Fly the boat......on the kissa......
  18. #27
    Jul 2004
    Connecticut
    Why can't you have both a pad and steps. Fountain Powerboats have been doing it for years.
    Agree. You can. These XCS 21's from Lavey have a delta pad and two steps. Unique design. Most of them were I/O over the years.
  19. #28
    Feb 2003
    Rochester, NY
    Hulls with both design features allow one to go fast without a ton of positive trim and still have the pucker factor in turns.
    1992 Progression 22
    Mercury Racing 250R
  20. Likes Greg G liked this post
  21. #29
    Nov 2020
    New Zealand
    If I want to post a bit of a time line of photos as the job progresses, which part of the forum would best suit?
    It may be of interest to some even for the humor factor.
  22. #30
    Nov 2005
    I own a twin step 27ft Chaudron Race boat and a pad vee 22ft Speedcraft open boat. They run completely different to each other and the suitable driving style is completely different. My stepped hull likes to run level and 1/3 of the hull remains wet at all time at WOT (80mph) with a single 300 XS and does not like negative trim. My padded speedcraft runs much drier at WOT (95-100mph) with a 250XS with only a couple of feet in contact with the water. Cornering is also different. I need to trim negatively on the padded hull when cornering hard to grip well whilst my stepped hull prefers cornering with a slight positive trim and "skids" its way around a corner. Obviously this does not apply to all stepped bottoms and my stepped Chaudron weighs nearly double of my padded vee Speedcraft hull so not really fair to compare.
  23. Thanks Greg G thanked for this post
  1. euro with ski bottom vs mod vp bottom
    By bigbluechevy454 in forum Technical Discussion
    Last Post: 03-27-2014, 06:03 AM
  2. bottom
    By jmr112 in forum Technical Discussion
    Last Post: 12-30-2001, 07:49 PM
