Results 1 to 2 of 2
06-04-2020, 12:25 PM #1New Member
- Sep 2011
- daytona beach florida
1997 55hp johnson Commercial help
Hey guys! I am trying to find information on a 1997 55HP johnson commercial i am interested in purchasing. I understand that they have lower compression to run low level fuel and that the gear case gearing could be off. It seems the gear case gearing is pretty close to a non-commercial engine. Is that correct?
Are parts able to be interchanged from non-commercial engines?
Can a noncommercial lower be put on the commercial engine?
Is the 55hp commercial a 60hp head with a lower gear case?
Can I put better reeds on the engine for better top end?
Also, what power pack do I need in order to not have a 5800 rpm rev limiter?
Engine is going on a 1648 .100 weldbilt.
Thank guys!
05-25-2022, 10:58 AM #2Junior Member
- Jan 2022
- Jacksonville Nc
Late response but I have same motor and have done some parts number comparing and some of the parts such as electrical, carbs, etc and the lower units are able to be swapped. Unsure on the powerheads but the reeds will help idle and overall performance, the power band will be smoother, not too much top end. You could always snip to the limiter wire. Good luck!
1979 Johnson 55hp 2 cylinder Good Compression
By baja030 in forum Outboard EnginesReplies: 2Last Post: 09-22-2017, 04:21 PM -
OMC Tech: Upgrade Johnson 55HP to 70HP
By Cerecerely in forum Technical DiscussionReplies: 7Last Post: 09-13-2017, 08:05 AM -
8 loop charge 55hp OMC - Johnson -Rude - New Wiseco Pistons
By BC Black Max in forum Ebay Listings and Other Internet ListingsReplies: 0Last Post: 05-14-2015, 02:40 PM -
55hp johnson 3 cyl and 75 hp johnson stinger
By john rowley in forum Technical DiscussionReplies: 1Last Post: 05-02-2011, 02:32 PM
