Results 1 to 9 of 9
Thread: Sportmaster lower unit
06-04-2020, 09:53 AM #1
My fat shaft doesn't have a hole for cotter pin ? Is that normal ?
Patriot Missile
06-04-2020, 10:42 AM #2
Yes . The Fat Shaft uses a 3 washer system . First big spacer goes on after the prop , then the conical bellville washer , then the final flat washer and fresh Nylock propnut . Torque to spec unless you have years of mechanical experience tightening things or you could over or under tighten the nut .
Dave Strong, tux974 liked this post
06-04-2020, 06:19 PM #3
They all look the same? One is fat two are the same.
Patriot Missile
06-05-2020, 04:59 AM #4
06-05-2020, 08:24 AM #56000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
06-08-2020, 10:35 AM #6
06-08-2020, 10:48 AM #7
06-08-2020, 05:47 PM #8
What is the torque specs
1986 cougar mtr 21
2003 supra launch ssv
06-08-2020, 06:03 PM #9
Min 55lb/ft.
sportmaster lower unit
By actioncraft17 in forum Technical DiscussionReplies: 3Last Post: 04-11-2010, 07:56 PM -
Sportmaster Lower Unit
By joeys20 in forum Technical DiscussionReplies: 0Last Post: 07-24-2003, 05:14 PM
