Results 1 to 9 of 9
    Jan 2005
    New York
    Sportmaster lower unit
    My fat shaft doesn't have a hole for cotter pin ? Is that normal ?
    Patriot Missile
    Yes . The Fat Shaft uses a 3 washer system . First big spacer goes on after the prop , then the conical bellville washer , then the final flat washer and fresh Nylock propnut . Torque to spec unless you have years of mechanical experience tightening things or you could over or under tighten the nut .
  3. Likes Dave Strong, tux974 liked this post
    Jan 2005
    New York
    They all look the same? One is fat two are the same.
    Patriot Missile
    Quote Originally Posted by R.I.P. View Post
    No, they are not, look closely. One is a little thinner which goes in the middle.
    If you have 2 the same thickness someone swapped them.
    Aug 2015
    Southeast
    Quote Originally Posted by tux974 View Post
    And it has a slight curve. Lay the two thin one's together from each side and you will be able to rock one of them back and forth a lil bit That's the one that gets sandwiched.
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship"
    Blazer 650 Pro Tour
    Jul 2005
    panama city,fl
    Quote Originally Posted by DangerNewb View Post
    The middle one that is conicaled , does it matter which way it goes on the shaft?
    Quote Originally Posted by robert jordan View Post
    High side up.
  9. #8
    Sep 2009
    Cleveland, Ohio
    What is the torque specs
    1986 cougar mtr 21
    2003 supra launch ssv
  10. #9
    Min 55lb/ft.
  1. sportmaster lower unit
    By actioncraft17 in forum Technical Discussion
    Last Post: 04-11-2010, 07:56 PM
  2. Sportmaster Lower Unit
    By joeys20 in forum Technical Discussion
    Last Post: 07-24-2003, 05:14 PM
