Results 1 to 6 of 6
    May 2019
    Australia
    SST 120 Midsection Transom Bracket Advice needed
    Hi All,
    I have a 12 inch mid which I have just removed from my F2 tunnel boat and noticed some play between the transom bracket and the swivel bracket held together by the tilt tube.
    My question is there a set of wear bushes over the tilt tube, I cant seem to find any part listing.
    I would think a well lubricated firm fit is how its meant to be with bushes or is this a metal on metal ??
    If anyone has experience with these please share.
    Regards Wayne.
    Apr 2020
    Illinois
    Definitely not an sst, but my 200 has the single ram trim and it moves around a little at the tilt pin, but as soon as any load is on it, me pushing back of motor, it tightens up and doesn’t move at all. I was just gonna leave it be but if any of you guys have a fix I’m down.
    83 Baja 20BR- 2.4 200 67mph gps
    91 concord Mach1- 2.5 200 (dads) 78mph gps
  3. Thanks WayneMac2 thanked for this post
    Celina, Ohio
    I've had lots of 12" mids. The tilt tube is metal to metal. If you look at the parts list there are no bushings.
  5. Thanks WayneMac2 thanked for this post
  7. Thanks WayneMac2 thanked for this post
    #5 to pinch the thing together, mine wore the tube out and still was a bit sloppy so we made a new tube and bored the sections for delrin bushings.
  9. Thanks WayneMac2 thanked for this post
  10. #6
    May 2019
    Australia
    Thanks Guys,
    Pulled it apart today and yes as per the parts list its metal on metal.
    I will discuss with a machinist and see which way is the easiest/best way to go
    larger shaft and keep as metal on metal or bush it
    Cheers Wayne
  1. transom repair advice needed
    By cocacola in forum Fiberglass and Composites Discussion
    Last Post: 04-04-2007, 03:20 PM
  2. Transom mounting bracket help needed
    By Kirkt in forum Technical Discussion
    Last Post: 05-28-2002, 03:50 PM
