Results 1 to 6 of 6
Thread: Promax piston skuffing
06-03-2020, 10:49 PM #1
What caused this skuffing on #5?
I had high water pressure 25#
And the buzzer went off. A month ago.
At a diffrent time.. also felt a loss of power after a long high rpm run . Felt like a cyl stopped firing.
Then last week herd piston slap. So I shut it down and tore it down.
Is this from lack of fuel?lube?
Overheat?
225 Promax
Factory staff and t stats. popet
06-04-2020, 05:33 AM #2
Damn I hate to see that, I'll go out on a limb and say looks like heat to me
06-04-2020, 08:26 AM #3
Id guess a little lean on that hole tightened the piston up juuuuuust a bit more than the others. Premix or injected motor? If the oil mix aint right that also affects combustion heat
06-04-2020, 09:26 AM #4
40-1 premixed. Injectors just cleaned 10hours ago.
Probly lean to pulse pump and Vst not keeping up with the demand on a long run.
06-04-2020, 05:25 PM #5
06-04-2020, 08:02 PM #65000 RPM
- Jun 2014
- United States
- 152
- 30
- 41
Get yourself a good dual readout pyrometer like a Koso and keep it under 1200 degrees. I had to get an ACU and a steam wheel.
Promax piston and rod wanted
By largecar91 in forum Parts WantedReplies: 1Last Post: 09-30-2016, 03:49 AM -
Mercury Tech: 300 ProMax Piston Differences
By Propster in forum Technical DiscussionReplies: 0Last Post: 08-09-2010, 06:13 PM
