Results 1 to 6 of 6
    Promax piston skuffing
    What caused this skuffing on #5?
    I had high water pressure 25#
    And the buzzer went off. A month ago.
    At a diffrent time.. also felt a loss of power after a long high rpm run . Felt like a cyl stopped firing.
    Then last week herd piston slap. So I shut it down and tore it down.
    Is this from lack of fuel?lube?
    Overheat?
    225 Promax
    Factory staff and t stats. popet
    Sep 2017
    Ashland city tn
    Damn I hate to see that, I'll go out on a limb and say looks like heat to me
    Jun 2018
    Floating around
    Id guess a little lean on that hole tightened the piston up juuuuuust a bit more than the others. Premix or injected motor? If the oil mix aint right that also affects combustion heat
    40-1 premixed. Injectors just cleaned 10hours ago.
    Probly lean to pulse pump and Vst not keeping up with the demand on a long run.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by roadkill636 View Post
    Is it to the point of runnin out of fuel on long run ? Like start to die till u back off? I have a glass filter to watch for that sort of thang , I ve ran a few dry b4 and start to die but never had a prob like that
    Jun 2014
    United States
    Get yourself a good dual readout pyrometer like a Koso and keep it under 1200 degrees. I had to get an ACU and a steam wheel.
  1. Promax piston and rod wanted
    By largecar91 in forum Parts Wanted
    Last Post: 09-30-2016, 03:49 AM
  2. Mercury Tech: 300 ProMax Piston Differences
    By Propster in forum Technical Discussion
    Last Post: 08-09-2010, 06:13 PM
