Results 1 to 10 of 10
Thread: Frankenstein promax
06-02-2020, 09:14 PM #1
Frankenstein promax
I bought an Allison that had this powerhed on it. I was told it ran real strong (built for drag racing) until water got into cylinders between the sleeve and the head. Said it needed 2 sleeves. Looks pretty good on the inside. Has a lite flywheel.
Whats it worth? Probably more if I part it out...Lets ask $1500 complete
Tim 919-88nine-22zero1
if you want it shipped you have to set it up. I will be glad to drop it off strapped to a pallet
06-02-2020, 10:52 PM #26000 RPM
- May 2001
- Madison, WI
- 1,145
- 253
- 37
- 494
- 196
WOW! look at that! Wonder how all that works. Retro 2.4 horn. Did he say what kinda box he ran on it? Is that an epoxy block modification up by the top starter mount or is that just spoo?
06-03-2020, 03:55 AM #3
Ouch. Good eye. she's little ruff but could be built rite again
06-03-2020, 06:24 PM #45000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
Who said it needed 2 sleeves ?
06-03-2020, 07:00 PM #5
Crazy eh? So I forgot it has a modified promax box and runs a 56# regulator ( I do not have that). I am going to call that epoxy a block repair..
James Martin is who I got it from..Here is the description in his adMotor is Frankenstein 225 horn blown and will need building and 2 sleeves and small weld on sleeve support. Very nice mild grind on inside. Motor ran well after we figured it out till head gasket failure.
06-03-2020, 07:05 PM #6Screaming And Flying!
- Dec 2001
- 9,502
- 269
- 191
- 1975
$1500 and no starter?????? He...….HeeHeee,,,,, just kiddinnnn
06-03-2020, 07:17 PM #7
Heck no man I gotta starter too!...look close in the pics and you can see it in 2 of them on the dolly
06-03-2020, 08:27 PM #8
Box pics
06-03-2020, 08:31 PM #96000 RPM
- May 2001
- Madison, WI
- 1,145
- 253
- 37
- 494
- 196
I had that same epoxy mod on a 280 I had. I was as told that mod let it run 10K before the rod end opened the block for more air flow and power above 10,000. Worked really good on mine for a little while.
If I had the balls I would buy it and give it a twirl. However, I don't think I could handle it anymore. Sure is neat looking. Love the horn modification. Bad Ass.
rgsauger liked this post
06-03-2020, 09:01 PM #10
Lol. well just keep it to 9k so both you AND the block will live
2.5L Promax Frankenstein
By Superchicken in forum Outboard EnginesReplies: 2Last Post: 04-21-2016, 06:33 AM -
Frankenstein's Monster...
By PSDPlayer in forum Technical DiscussionReplies: 9Last Post: 09-07-2014, 01:18 PM -
Mercury Tech: What is this Frankenstein and why won't it go???
By Motion22 in forum Technical DiscussionReplies: 4Last Post: 04-16-2014, 11:35 AM -
Frankenstein Typical Rat.
By Steve 1 in forum The Scream And Fly LoungeReplies: 2Last Post: 02-09-2009, 04:47 PM
