Results 1 to 15 of 16
    Jun 2020
    east coast
    Bad Stator? Mercury v6 Blackmax
    Rough Idle, misses through range. Seems to have intermitent miss on all cylinders.
    Here are some stats.
    Stator Resistance
    Blue to gnd 4.5k vs spec 5-7k ohm
    Blue/wht to gnd 6.4 vs spec 5-7k ohm
    Red to gnd 71 vs spec 90-200 ohm
    Red/wht to gnd 155 vs spec 90-200 ohm
    Trigger specs out resistance wise.
    Can't seem to get stable DVA readings, cheap multimeter?
    New to Scream&Fly
    Thanks!
    Aug 2006
    GA
    Cook your Carb's
    Jun 2020
    east coast
    partially rebuilt the carbs this winter, but didn't replace needles & seats, they looked fine.
    Houston, TX
    Just a question, have you checked your compression? Have you done a thorough decarbon treatment on it?
    Houston, TX
    Replaced your plugs this year?
    Sep 2017
    Ashland city tn
    1st off. Welcome to scream and fly. I dont have a manual in front of me ,but if ur comparing ur #s to the manual , then yes it looks like it could b bad , then again , I have a stator that dont read what manual says and it works fine , maybe is was my meter idk , so u no it's all 6 that's missin? Have u done spark test?
    Jun 2018
    Floating around
    Agreed my dva readings were not all as they should be on a stator I replaced and it ran perfect. I went through a pile of BS with my first V6 merc and ended up with a new stator and spark boxes and it ran mint after that. I’d probably just replace both considering the age and the common issues there if you start fresh with those you can be certain those are good. The key switch too can be troublesome on these if it’s worn it can mess up the ign circuit
  8. Likes XstreamVking liked this post
  9. #8
    The 2 volt regs can screw up the stator too. They are part of the ign circuit so check em. If they are potted with clear resin then def change them.
    Jun 2020
    east coast
    Quote Originally Posted by rgsauger View Post
    Ran almost a full bottle of straight seafoam into the the carbs, and cylinders to winterize. Will do another decarb when its on the water to get the throttle up. compression is "ok". 110-115 per cylinder.
  11. #10
    Jun 2020
    east coast
    That would be the square box connected to the rectifier? Have an all-in-1 requlator/rectifier to replace both on order.
  12. #11
    Jun 2020
    east coast
    Quote Originally Posted by Merc 2.5 View Post
    Thanks!
    Cheap windowed spark tester showed intermittent spark on all cylinders, checked with timing light too.
    Will check with a spark gap tester when I find 1.
    I'd like to verify the DVA voltages though either my meter or the adapter I made won't allow a stable reading.
  13. #12
    Jun 2020
    east coast
    I have also removed the idle speed stabilizer and need to do a link n sync. Is the 23* timing advance across the board, or engine specific? Spec for my motor is 18* btdc.
  14. #13
    Feb 2014
    Missouri
    Random unreadable voltage could be meter, stator, or magnets see if any are lose or missing.
  15. #14
    Jun 2020
    east coast
    Thanks Motv18,
    My cheap dvm has no hold feature. Gonna try an analog meter. Waiting on a flywheel puller to inspect it.
  16. #15
    Sep 2017
    Ashland city tn
    18deg is with the timin box , it will advance it 4 or 5 deg wot
    If it's a 150 ,21deg good starting point , 200hp 23 deg. Thise will be a safe # , if ur racing it can up little more
  1. Replies: 44
    Last Post: 11-26-2019, 08:44 PM
  2. Mercury Tech: Blackmax is overcharging - Stator?
    By Zaairman in forum Technical Discussion
    Last Post: 05-06-2016, 01:40 PM
  3. Mercury Tech: 1987 V200 Blackmax stator replacement.
    By graham180869 in forum Technical Discussion
    Last Post: 08-25-2012, 09:52 AM
  4. Mercury 150 blackmax
    By argo-catt in forum Technical Discussion
    Last Post: 08-19-2012, 10:39 AM
