Results 1 to 8 of 8
Thread: Overheating Issue
06-01-2020, 05:49 AM #1Junior Member
- Nov 2013
- Eustis Florida
- 12
Overheating Issue
1993 175 hp Merc. OK at low speed and high speed, overheats, 170+, at medium speed (2500-3500rpm), then cools if speed is increased to high (over 4500+ rpm). Water pump and both thermostats have been replaced and water stream looks good. Any thoughts? Poppet valve?
06-01-2020, 06:42 AM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Not a legit fix, butt....I cut 2 coils off the spring in the poppet on my 2.5 200. It had the same symptoms. Runs 145 now all the time. Instructor at merc school said it might fix some engines. You might also try a new spring? The problem occurs when the poppet is taking over for the stats. Poppet just opens easier with less water pressure needed.
06-01-2020, 10:57 PM #3
06-02-2020, 04:38 AM #4Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Water press seemed to stay about the same. It runs about 20 psi at wot. 12 or so at 3500 cruise.
06-02-2020, 04:57 AM #5
06-02-2020, 05:51 AM #6Junior Member
- Nov 2013
- Eustis Florida
- 12
06-02-2020, 06:14 AM #7
06-02-2020, 06:15 AM #8
no mater what tha rest "looks like" best ta replace it all.. tha stainless parts (cup in tha housing and tha ride plate) will look jus fine but still be wore.. same with all gaskets.... jmo.
Mercury Tech: Dual temp gauges issue OR engine Issue
By dompie99 in forum Technical DiscussionReplies: 4Last Post: 05-24-2016, 09:37 AM -
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
overheating issue? Poppet valve?
By Valero2.5 in forum Technical DiscussionReplies: 11Last Post: 06-23-2015, 06:56 PM -
Mercury Tech: Overheating
By GUIDO in forum Technical DiscussionReplies: 4Last Post: 08-17-2010, 10:02 PM -
225 overheating
By Quick Rick in forum Technical DiscussionReplies: 2Last Post: 07-07-2006, 04:02 PM
