Results 1 to 6 of 6
Thread: 300xs fuel line question
05-31-2020, 02:04 PM #15000 RPM
- Jul 2016
- columbia sc
- 190
On a 2017 mercury 300xs is there supposed to be a primer bulb on top of the tank. I had one for my old motor can I do without that? Thank you for the help and your time.
05-31-2020, 02:21 PM #2
I’d leave the primer bulb , in case ya ever run out of gas . Hf...
05-31-2020, 09:20 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
You shouldn’t need it, but their handy when you don’t have a ddt or the duck valve gets opened.
06-01-2020, 08:34 AM #4Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
You do need a primer. If you hit it and fill the vst before initial starting it will help to prolong the life of the low and hi pressure pumps. There is a priming procedure using the primer. Hit the bulb. Turn the key for 10 secs. Turn off. Prime again. Hit key, 10 sec, off. Do this several times to completely fill the vst and eliminate air. Opt's are very fuel sensitive. Pumps will fail if not fully primed.
Dave Strong liked this post
06-01-2020, 01:16 PM #55000 RPM
- Jul 2016
- columbia sc
- 190
Ty for the input!!
06-01-2020, 06:23 PM #6
My buddies' boat is a 2004, only time he ever hits the primer is when he changes filters.... he can let the boat sit for 3 months and it will fire right up without the primer, in 16 years, has not lost a pump....... But, yes, the right way to do it is to pump the bulb until it's hard before you start it up after sitting fo more than 12 hours.....
Fuel line to fuel filter leak that's not making any sense. Is Trident Fuel Line good?
By Bumblebeeman in forum Technical DiscussionReplies: 7Last Post: 10-06-2019, 02:52 PM -
Mercury Tech: Fuel line question
By Mini GT in forum Technical DiscussionReplies: 8Last Post: 05-25-2014, 11:27 AM -
Fuel line question...
By crankn101 in forum Technical DiscussionReplies: 17Last Post: 03-04-2013, 05:49 PM -
Fuel Line on 300xs
By Diamond Performance in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 07-20-2008, 10:48 AM -
Mercury Tech: Fuel Line on 300xs
By Diamond Performance in forum Technical DiscussionReplies: 2Last Post: 07-13-2008, 09:10 PM
