Results 1 to 4 of 4
    Netherlands
    Dts /shift problem Mercury Verado 250hp 2006
    Hello,
    Hopefully somebody can help.
    I got a 2006 verado 250 hp low hours 200.
    From beginning we got issues with the throttle lever. Bought engine without rigging and ask the dealer to buy everyting new for plug and play they send a guy with cds computer to install everytime the modules don't fit the engine. So he decide to try a old throttle lever from approx same age. Far so good looks like everything works fine. Then sometimes when shift to reverse it gives a warning sound and no fault code on sc1000. It stops when turn of the key. 1 time dangerous moment (always happen reverse) sound get in so we shift neutral and forward instead of forward the engine goes backwards.... So turn of the key directly (it happen 1 time) sometimes all run great sometimes it gets in. Tried to make a movie on the floating dock.
    Movie:
    https://youtu.be/7vAnzJ5hrUI
    Boat: Hydrostream virage
    Engine: Mercury 300 XS DBR 1.3
    Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
    Max speed: 113mph
    Jul 2011
    Gloucester, VA
    Im betting its a Shift switch and actuator sensor misagreement. They did away with the switch in later years. Test the switch
  3. Thanks darkdream thanked for this post
    Netherlands
    Thanks for this post where can I find the switches? Are they located inside the throttle lever? Iam new with verado engines my other boat has a optimax. Hope I finally can fix this issue. The brand new 2019 throttle lever don't have problems with shifting the new handle was not possible to use powertrim on the handle the mercury technican said, so he decide to run a old used handle he find in storage. First day and on the CDS computer it works perfect. Nothing changed after first day.
    Max speed: 113mph
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by darkdream View Post
    In the motor. Front and center. Small box
  6. Thanks darkdream thanked for this post
  1. 2006 Mercury Verado error Code Sc1000 display
    By davepnola in forum Technical Discussion
    Last Post: 05-11-2018, 06:56 AM
  2. 2008 Mercury Verado 250HP Dressed Powerhead
    By MERCSPEED in forum Outboard Engines
    Last Post: 11-18-2015, 04:45 PM
  3. Mercury Tech: 2006 225 optimax to 250hp
    By aaronmt73 in forum Technical Discussion
    Last Post: 02-24-2010, 10:46 PM
  4. Yamaha 3.1 liter 250hp vmax Vs. Mercury 250hp ???
    By slayer in forum Technical Discussion
    Last Post: 02-13-2005, 09:01 PM
