Results 1 to 3 of 3
Thread: Hot sensor? ?
    May 2020
    Toledo Bend Lake
    Hot sensor? ?
    My J90 has been going through some little issues. Yesterday, while idling at the dock, cowling off, the rpm started to increase from its "just above idle" setting. When I got to the control and reduced the rpm there was heavy smoke coming from the port side of the engine! Taking the bailing scoop I poured water on what looked like fire! Soon as I cooled everything down I discovered, no fire, but a little cylindrical item, much like the old turn signal blinker on automobiles. I have not found any description on wiring diagrams that match the size or location of this part. I have a picture of where it is but can't seen to load it.Click image for larger version.
ID:	466764 OK here it is!
    Apr 2020
    Illinois
    Looks to me like a rectifier. Converts ac voltage from the stator to dc voltage to run your boat/charge battery. Those can and will go up in smoke like that. But check for corroded wires. The sheilding gets old brittle and flakes off, and the wire inside will corrode. Look for any oozing glue coming out of it or if it just looks burnt in general. I don’t know if a stator can ruin rectifiers or not.
    83 Baja 20BR- 2.4 200 67mph gps
    91 concord Mach1- 2.5 200 (dads) 78mph gps
  3. Thanks OLE GAR thanked for this post
    Ft. Lauderdale, Fl
    Quote Originally Posted by 91concord View Post
    Loose battery connections can make those give up the ghost too
  5. Thanks OLE GAR thanked for this post
  1. Verado Pro 300 water pressure sensor and speedometer sensor...
    By JUPITER PULSARE in forum Technical Discussion
    Last Post: 03-04-2018, 12:47 PM
  2. Identifying this sensor on 2001 300x, knock sensor?
    By turbo94gto in forum Technical Discussion
    Last Post: 04-11-2013, 11:14 PM
  3. Mercury Tech: ait sensor/mass air flow sensor
    By ddantidwell in forum Technical Discussion
    Last Post: 03-27-2011, 10:59 PM
