Results 1 to 15 of 17
05-29-2020, 01:34 PM #1Junior Member
- Oct 2019
- Finland
- 28
Damn old Johnson!! Need assistance from wiser ones..
Johnson 225hv 88year. Old owner had burnt rectifier and i replaced it, now charges and rpm is working. Same time i replaced waterpump, everything on it. When test runned it in water barrel it peeped long alarm couple times. It is staying cool not getting heat top of the block. Putted it in water and gettin plane...nice smooth rode about 5mins and loooong lasting peep and drops revs down to 3000rpm. You can drive idle but not over 3000rpm. Taking powers off it zero's fault and let it go on plane again and ofcourse peep long lasting. Checked gasoline pump and it was ok, i have electric assembled after filter. Filter replaced also. So is it how possible that heat sensors has also burned same like rectifier??? VRO also old owner has deleted and i mix oil straight to tank...
05-29-2020, 06:08 PM #2
Got thermostats on that thing? If so check em by putting em in boilin water see if they open
phillnjack liked this post
05-29-2020, 07:00 PM #3
Also, make sure the VRO wiring harness is disconnected.
On the cooling side.... was the impeller broken up? Or maybe one broke up with the old owner..... might have pieces clogging op the cooling system"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
LakeFever, phillnjack liked this post
05-30-2020, 02:33 AM #4Junior Member
- Oct 2019
- Finland
- 28
05-30-2020, 05:03 AM #5
Add a temperature gauge to verify the buzzer is working properly
05-30-2020, 07:36 AM #6
Lake is right, you need to verify the temperature. You can do this one of two ways; either use melt sticks or a hand held temperature gun to check the temperatures. Check at the top of the cylinder heads near the thermostats. And as said before make sure there are thermostats install and they are working correctly. The temperature senders could have gotten sprung during a good overheat and might be tripping at lower temperatures.
Have you tested the thermostats?"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
05-30-2020, 08:36 AM #7
Theres those infra red temperature tools too. Not sure if you'll get an accurate reading of what the coolant temp is but you should be able to figure out if its overheating with one. Certainly the fastest way
05-30-2020, 09:38 AM #8Junior Member
- Oct 2019
- Finland
- 28
[QUOTE=flabum1017;3210865]Lake is right, you need to verify the temperature. You can do this one of two ways; either use melt sticks or a hand held temperature gun to check the temperatures. Check at the top of the cylinder heads near the thermostats. And as said before make sure there are thermostats install and they are working correctly. The temperature senders could have gotten sprung during a good overheat and might be tripping at lower temperatures.
Yes i checked the thermostats altough i didnt boil them. More interested was the Johnsons system in water circulation wich is controlled with 2way valve and thats why i replaced waterpump because mark water is very little unless you give more rpm´s. I dont know how much it should get temperature after running or idle but both cases i can put my hand both blocks and i dont burn my hand not even close.
I am very same way with you that senders have got sprung in a good overheat and give false info.
05-30-2020, 10:03 AM #9
sounds like a simple case of temperature senders have gone bad. it happens. these are now very old and often go bad. probably find when you get them off they are corroded.
simply disconnect the wire from it and run a proper temp gauge on the heads.
the reason it goes down to 3,000 rpm is the S.L.O.W mode coming in at the power pack for over heating and no oil alarm thing... its meant to do that very thing..
I would definitely go straight for bad temp sensors. I had exactly the same thing on a 1995 3 cyl rude.
P.S when running in a water butt, make sure you have a hose running in the butt as well because the water in there warms up very quickly unless its a huge tank !!!Last edited by phillnjack; 05-30-2020 at 10:06 AM. Reason: terrible spelling mistakes
05-30-2020, 10:08 AM #10Junior Member
- Oct 2019
- Finland
- 28
06-01-2020, 08:52 AM #11Junior Member
- Oct 2019
- Finland
- 28
Was doing test today and disconnect single brown from temp sensor and still long peep and slow mode. Checked other side sensor two wires and noticed that white/black was connected to tan wire and tan wire was connected to white so changed them other way and no peeps anymore. Runs perfectly!!!!!
LakeFever liked this post
06-01-2020, 09:32 AM #12
Damn wiring... Someone wiring w/o their glasses
'84 Checkmate Convincor
06-01-2020, 09:35 AM #13Junior Member
- Oct 2019
- Finland
- 28
06-01-2020, 09:52 AM #14
06-01-2020, 10:02 AM #15Junior Member
- Oct 2019
- Finland
- 28
Haha yes i didnt thinked so. Just sayin that because i havent noticed that someone wired them cross.
Is Older Wiser?????
By mirage243 in forum The Scream And Fly LoungeReplies: 2Last Post: 10-18-2010, 02:22 PM -
Damn wind damn trees
By sunapeeboater in forum The Scream And Fly LoungeReplies: 16Last Post: 03-02-2010, 11:03 AM -
looking for any assistance in PA
By cvx-20 in forum Jet Boats, V-Drives and Stern DrivesReplies: 14Last Post: 03-10-2009, 01:01 PM -
V 4 tuning assistance
By 150aintenuff in forum Technical DiscussionReplies: 5Last Post: 04-08-2008, 04:31 AM -
Is it possible that the black voters are getting wiser?
By Raceman in forum The Scream And Fly LoungeReplies: 6Last Post: 08-09-2006, 06:48 PM
