Results 1 to 1 of 1
Thread: Ever seen tilt cyl drift UP?
05-28-2020, 11:53 PM #1Junior Member
- Apr 2020
- Illinois
- 13
So the currently I’m piecing my motor back together from getting painted, and only have the single ram bracket and all on and together. After connecting all my lines and bleeding the cylinder/pump it drifts up really slow like air expanding or something, but is rock solid and doesn’t move up or down like an air pocket would suggest. It also trims down waaaaay slower than trimming up. Has the junk square motor/round tin can reservoir pump. I’m also using power steering fluid if that makes a difference. Any idea if it’s just the weight of the motor not being on it causing this?
83 Baja 20BR- 2.4 200 67mph gps
91 concord Mach1- 2.5 200 (dads) 78mph gps
Car vs. Bike II drift
By Stoker1 in forum The Scream And Fly LoungeReplies: 0Last Post: 07-26-2012, 12:07 PM -
Tilt n tilt wiring 1977 johnson 140hp ?
By phillnjack in forum Technical DiscussionReplies: 6Last Post: 02-28-2011, 01:47 PM -
Motorcycle vs. Car Drift Battle
By Robby321 in forum The Scream And Fly LoungeReplies: 5Last Post: 02-03-2011, 09:21 AM -
Mercury Tech: teleflex pro Hydraulic Mota Drift!!
By bigboatin in forum Technical DiscussionReplies: 10Last Post: 07-13-2010, 11:05 AM -
Found a tilt lock block off plate and SS SOLID tilt pin
By Skater 32 in forum Technical DiscussionReplies: 0Last Post: 03-22-2010, 09:12 PM
