Results 1 to 1 of 1
Thread: 250 sho guru's
05-28-2020, 10:40 AM #15000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
250 sho guru's
Proplem I'm having is if outside air temp is under 70° motor runs great whether the motor is hot or cold, if air is above 70° it's slow out the hole bogging kinda, also sometimes you hit the throttle to come out the hole it hits wfo for about 3 seconds and then goes back to bogging, but once it breaks over it runs like it should, also wont turn more than 5800-5900 rpms, my buddies have same boat and setup and they turn a 27 at 6100 , hp pump replaced, new fuel lines, every thing has been tested to yamaha specs, as per manual, just dont know
Who Is The Omc 3.6 V8 Guru...
By VELOCITOY in forum Technical DiscussionReplies: 10Last Post: 04-16-2009, 12:49 PM -
Need a 280 Guru's help!!
By skywagon in forum General Boating DiscussionReplies: 16Last Post: 05-27-2004, 02:37 PM -
260 Guru's
By WaterBoy in forum Technical DiscussionReplies: 24Last Post: 01-04-2004, 02:54 PM -
I'm a GURU
By Doubledog in forum General Boating DiscussionReplies: 3Last Post: 05-02-2003, 10:27 PM
