Results 1 to 1 of 1
Thread: Johnson 125 help please
05-25-2020, 11:50 AM #1Member
- Jan 2009
- Florida
- 50
I have a 125 that is new to me and it is a model number j125esxess... The problem i am having currently is the water control valve (discontinued) is leaking bad and i am wanting to bypass it. I have heard you can use thermostats , springs , and covers from a 1989 70 hp johnson. The only problem with this is they are discontinued which other covers and thermostats will work ??
Johnson 175 faststrike vs johnson 225 ho fuel economy
By PARKBOY in forum Technical DiscussionReplies: 9Last Post: 05-14-2015, 09:20 PM -
OMC johnson 225 v6 vro technical date(comp. 225hp 2tEvinrude-suzuki-Johnson-mercury)
By Flabenk69 in forum Technical DiscussionReplies: 6Last Post: 05-02-2015, 11:27 AM -
OMC Tech: Mixing and matching Johnson 140 powerhead to johnson 200 mid section and lower unit
By stonebreaker in forum Technical DiscussionReplies: 11Last Post: 04-16-2012, 07:24 PM -
OMC Tech: 1990 johnson 225 powerhead to a 1994 johnson 150 midsection??
By 85HYDROSTREAMVECTOR in forum Technical DiscussionReplies: 1Last Post: 03-02-2011, 08:20 AM -
1978 Johnson Stinger vs. mid 1980 Johnson's
By fairbanks 1977 in forum Outboard and Racing HistoryReplies: 2Last Post: 08-04-2006, 06:40 PM
