Results 16 to 30 of 31
Thread: 95 Mariner 200 Carb info needed
05-26-2020, 07:01 AM #16
thinkin' '95 shoulda been all plastic???
05-26-2020, 07:04 AM #17
Hell I thought his was all plastic , well it looks the same anyway. I didnt no they had a plastic and a plastic/metal. Is the metal on inside?
05-26-2020, 07:07 AM #18
no, its all metal with a front that comes off..... yours should also only have two inlets on each side..
05-26-2020, 07:11 AM #19
05-26-2020, 07:12 AM #20
I see now. says the blind man
rgsauger liked this post
05-26-2020, 07:18 AM #21
05-26-2020, 08:45 AM #22
Great info gents thanks! The motor is stored at this gentlemans cottage so neither of us has access to it at the moment. Plan is to check it out this weekend, then of course I find a 96 200efi last night that I'm going to see first. The guy who owns the motor I posted the pics of is super decent but is not a mechanic type so hes trying to inform and has tapped out with regards to what I posted earlier. He seems to think its a 95 and went quiet when I inquired if it was a 2.4 or 2.5 I dont think he evens knows what that means. I'll get the serials and see whats what and report back. Thanks again!
05-26-2020, 03:31 PM #23
05-26-2020, 03:43 PM #24
did you even look at tha drawing of tha parts i posted???.. course not.. it came out in '89... his motor doesn't even have dowel pin block or heads.... its pre '91 no mater what it is.
05-26-2020, 03:43 PM #25
No. I seen them when tommy pointed it out to me , that had me little screwed up
05-26-2020, 03:49 PM #26
05-26-2020, 03:57 PM #27
they have a little "bulge" for a hole jus to tha side of tha sloted water outlet on both ends of tha head ta accommodate tha dowel pin in tha block.....
05-26-2020, 04:06 PM #28
if you look here you can see tha holes by tha outlets.. thats where tha little bulge on tha outside shows up....
https://www.screamandfly.com/showthr...ighlight=heads
Merc 2.5 thanked for this post
05-26-2020, 10:04 PM #29
This looKS a helluva lot like my 90 model V200......2.4
LakeFever thanked for this post
05-26-2020, 11:02 PM #30
yeah, its more than likely a a '89/'90 2.4 "something" for sure.....
you can go here and see where tha parts make changes by year and with serial number splits....
https://www.crowleymarine.com/mercur...ser_parts.html
Mariner XR6 150 hp Info/opinions
By funkj92 in forum Technical DiscussionReplies: 2Last Post: 07-29-2013, 03:01 AM -
Urgent info needed on 40a mariner 80s engine.
By furious cub in forum Technical DiscussionReplies: 7Last Post: 06-28-2013, 06:35 AM -
2.4 Merc Carb Info needed
By shooter1 in forum Technical DiscussionReplies: 0Last Post: 03-28-2005, 11:57 PM -
Need info on mariner 2.5
By gary mclemore in forum Technical DiscussionReplies: 2Last Post: 02-12-2005, 06:38 AM -
Looking for Info/Opinions on '87 220 Mariner
By Hydrasports205 in forum Technical DiscussionReplies: 2Last Post: 01-25-2005, 09:10 PM
