Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Jun 2018
    Floating around
    95 Mariner 200 Carb info needed
    Looking to buy one and it has a black engine under the grey cowl, guy claims he is the original owner is this common or is do you think its had the powerhead swapped? Any block numbers or anything specific to check on these? Are they 7petal? FF block or no? If I buy it im going to ditch the black boxes, injection and run 50:1 pre mix. Any pointers welcome if I missed asking anything. Looking for a good check list
    Jun 2018
    Floating around
    Something aint right here this is the cover which looks like a 91 to me? What I really am most concerned about is making sure its a 2.5
    Sep 2017
    Ashland city tn
    I'm not 100% sure without serial but kinda looks like 2.5 with that side cover I guess. Never seen one on a 2.4. Get serial behind timin arm or Welch plug
    Carbs prob tell alot also. What are they , wmh , wmv , wh ?
  4. Thanks LakeFever thanked for this post
    Florida Keys
    I see hodgepodge.....
    WH carbs (2.4), ‘91 specific 200 airbox, if they’re 2.5 heads they a WAY early, red flywheel.
    my guess... was a 91 200 7 peddle Mariner that blew up and someone put a fat block 2.4 on.
    '95 STV "The Blue Goose"
  6. Thanks LakeFever thanked for this post
    Houston, TX
    Serial number should be on top, starb side, between head and flywheel on silver disc/plug
  8. Thanks LakeFever thanked for this post
    TX......somewhere?
    black powerhead common deal.. serial number here maybe...
    build date stamped on block, base of number two on block half kinda behind tha "bend in tha timin' arm..
  10. Thanks LakeFever thanked for this post
  11. #7
    Sep 2017
    Ashland city tn
    Is that a square fuel pump I see under oil injection pump? ,2.4 didnt come with square pumps ? Not that I've seen anyway, the air box is standard 2.5 box, did u try get serial#?
  12. #8
    TX......somewhere?
    Quote Originally Posted by Merc 2.5 View Post
    but they did.. maybe '86/'87 and later... coupla years coulda had either one.
  13. #9
    TX......somewhere?
    don't think heinz.. maybe '89/'90.. that air box showed up in '89.. its all metal with front that that comes off.. most everything after those years and including most during those years had tha 40 amp water cooled stuff... were a few out there with tha 16 mostly 135/150... few 175/200's... '89 up most XR4's had 40's................... jmo.
    Sep 2017
    Ashland city tn
    Ya I wasnt real sure but I had feeling toward end of 2.4s they were square. Thanks
    Florida Keys
    That’s not the standard 2.5 airbox
    it has the two extra inlets at the bottom. 1991 7peddle specific
  16. Likes LakeFever liked this post
    Florida Keys
    Any fat block 2.4 will have the square (2.5) pump.
  18. #13
    TX......somewhere?
    your absolutely right.. his motor is not a fat block or 2.5.. that box came out in '89/90 on some 2.4's.. it came ona '90 XR4 i bought.. only one i ever saw.. all tha 200's had tha "organ pipes" till '91............. so gotta disagree 'bout '91 specific.. was pretty much standard on horizontal 150/175's 2.4's
    https://www.crowleymarine.com/mercur...cfm?mdl=3E989T
  19. #14
    TX......somewhere?
    one thing for sure, its pre '91.... no dowels.
  20. Thanks LakeFever thanked for this post
  21. #15
    Sep 2017
    Ashland city tn
    Ya same air box came with my 2.5 (95) just wish he try get serial so we will no for sure. Fun tryin figure it out tho
  1. Mariner XR6 150 hp Info/opinions
    By funkj92 in forum Technical Discussion
    Last Post: 07-29-2013, 03:01 AM
  2. Urgent info needed on 40a mariner 80s engine.
    By furious cub in forum Technical Discussion
    Last Post: 06-28-2013, 06:35 AM
  3. 2.4 Merc Carb Info needed
    By shooter1 in forum Technical Discussion
    Last Post: 03-28-2005, 11:57 PM
  4. Need info on mariner 2.5
    By gary mclemore in forum Technical Discussion
    Last Post: 02-12-2005, 06:38 AM
  5. Looking for Info/Opinions on '87 220 Mariner
    By Hydrasports205 in forum Technical Discussion
    Last Post: 01-25-2005, 09:10 PM
