Results 1 to 7 of 7
Thread: Charger 18DL Stiff Steering
05-24-2020, 06:33 PM #1New Member
- Aug 2009
- Oshawa, ON, Canada
Just bought my first boat used and looking for advice on a steering problem.
2007 Charger 18DL
1988 Mercury XR2 150
HIJACKER Manual jackplate
Steering is very stiff basically all the time. Reading I have done leads me to believe I need to replace the cables. Helm says teleflex no feedback steering but no serial numbers. Single cable setup. Approx 13 ft long. 3 turns lock to lock.
Based on the photos attached, can you identify this steering setup? Is this acceptable or should it be upgraded? The boat has a 19pitch 4 blade on it so not very fast.
Is it possible to replace just the cable or do I need the complete system? What measurements do I need to confirm which cable I need?
05-24-2020, 07:34 PM #2
Welcome to the site. Might be a good time to invest in hydraulic. I know it is pricey but you will love it. I have had the rotary before and it worked fine but have never had it on a performance boat. Even with new cable it won't compare to hydraulic and sounds like you have a nice boat worth the investment. Good luck.
RockTeam Junk
05-24-2020, 07:38 PM #3
A good dual cable system is getting harder and harder to find, hydraulic is a great upgrade. The no feedback system is junk for high performance, it will lockup at speed. I haven't done it myself, but have heard it is possible to disassemble the helm and remove the rollers to eliminate the "no feedback" and it will act like a dual cable system.
Edit: just noticed it is a single cable, scrap that.
05-24-2020, 09:08 PM #4
Single cable on performance setup is not what you want. Hydro rocks.
05-25-2020, 05:30 AM #5New Member
- Aug 2009
Thanks for the feedback. Do you have any links to a hydraulic system you would recommend?
05-25-2020, 05:43 AM #65000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
If you’re considering hydraulic I’d look at SeaStar pro.
Readily available and realatively cost effective for your application.
Looking at your pics, you’d have a hard time getting your dual cables to make the bend out of the hole in your splash well with the setaback you’ve got on the boat.
05-25-2020, 09:34 PM #7
What he said. Seastar pro
Stiff Steering
By Bruce2 in forum Props, Setup, and RiggingReplies: 22Last Post: 04-22-2019, 05:00 PM -
18DL Charger Fiberglass Windshield Build
By Murph in forum Fiberglass and Composites DiscussionReplies: 18Last Post: 03-08-2014, 09:35 AM -
Stiff steering
By 03bignasty in forum Technical DiscussionReplies: 7Last Post: 01-11-2006, 10:35 AM -
Stiff Steering
By JohnI in forum Technical DiscussionReplies: 2Last Post: 07-18-2005, 11:34 PM -
Stiff Steering
By Electric Fish in forum Technical DiscussionReplies: 7Last Post: 09-08-2003, 09:19 PM
