Results 1 to 4 of 4
Thread: Mercury 2 + 2 125HP
05-24-2020, 02:24 PM #15000 RPM
- Dec 2003
- 190
Mercury 2 + 2 125HP
Hi all,
Some time ago I had posted information on a Mercury Outboard 2+2 125 HP. I asked about removing the rev limiter to run the motor at 5500. I was advised against this..
However, what I've been running into on these motors is a bit disturbing. Here is why:
A second rebuild has turned up the same issue. That is, a needle bearing missing on the lower main bearing. That's right this is my second 125 2+2 rebuild and both 125's have 23 needles in the lower bearing, should be 24. So to confirm I was counting correctly, I had two different buddies count two different times on both motors. What they saw they could not believe.
Now this may be a coincidence, but I doubt it. Is this why they vibrate above 5250 and could come apart above the RPM? Did mercury have a run of these motors with a missing needle?
What's going on here?
05-25-2020, 10:56 AM #2
Don't know what to tell you on the needle thing, but running over 5250 is not good. Its a harmonic deal that creates a vibration that knocks the crank out. The very first 2+2 motors had a rev limit of 5500 until they started knocking cranks out, fix was to drop the max rpm to 5250.
05-25-2020, 06:42 PM #35000 RPM
- Dec 2003
- 190
05-25-2020, 09:06 PM #4
They don't make any power much past 5200 either.
Dave Strong liked this post
95 Mercury 125hp Electrical Parts
By skatermike24 in forum Parts WantedReplies: 3Last Post: 01-17-2018, 04:37 PM -
Mercury Tech: 95 Mercury 125hp 4 cyl Help
By skatermike24 in forum Technical DiscussionReplies: 13Last Post: 01-11-2018, 01:22 PM -
Need to pick your brains, 99 125hp Mercury
By dpf-01 in forum General Boating DiscussionReplies: 8Last Post: 09-29-2013, 05:12 PM
