Results 76 to 88 of 88
Thread: High water pressure 225 promax
05-29-2020, 11:59 PM #765000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
One of you fellas that is trying to help out mentioned "does your water pressure bounce on the gauge?" what is that an indicator of if it is?
Bunger, brother... stay on topic man. You are all over the place worried about compression, plugs etc. Figure out your pressure issue and focus on one thing. Then worry about other crap. If you go messing with a bunch of other stuff all at the same time it is hard to determine anything.
06-07-2020, 10:42 AM #77
Just resolved my high water pressure issue, was a bad dash gage.
06-07-2020, 10:43 AM #785000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
That’s basically what I figured out. Gauge is super sensitive and I happened to get a super spunky new water pump. Boat runs great I’m sure the pressure will get back to normal once the pump wears in a bit
06-07-2020, 12:05 PM #79
I guess this would cause high pressure?
Dave Strong liked this post
06-07-2020, 12:22 PM #80
07-27-2020, 08:57 PM #81Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
07-28-2020, 06:14 AM #82
07-28-2020, 06:33 AM #83Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
What are the chances of 3 pebbles just the right size. Geez.
03-06-2024, 08:43 PM #84
OP...
Did you ever resolve your pressure issue?
Thanks
03-06-2024, 08:44 PM #855000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
03-06-2024, 09:53 PM #86
03-06-2024, 11:16 PM #87
03-07-2024, 07:25 AM #885000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
Probably something to definitely check if you buy a used motor and the paint is worn off the skeg and bullet... potentially a lot of beaching as rocks & gravel don't usually float.
High Water Pressure After Changng Water Pump
By maineidyl in forum Technical DiscussionReplies: 8Last Post: 08-11-2018, 05:10 PM -
Mercury Tech: High water pressure & low water temp
By njj502 in forum Technical DiscussionReplies: 158Last Post: 10-19-2017, 03:00 PM -
promax high water pressure
By ActivatedSludge in forum Technical DiscussionReplies: 23Last Post: 10-25-2014, 08:06 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM
