Results 31 to 45 of 88
Thread: High water pressure 225 promax
05-27-2020, 04:55 AM #31
Now that the power head is hanging pull the stat housings and try to back flush system.
From the looks of things I say your issue is elsewhere not in the block it self.
I would redo pump, check water tube, key way, guide tube, grommets etc....JMPO
Dave Strong liked this post
05-27-2020, 09:35 AM #325000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Waiting on gaskets and I’ll get it back together. Also ordered mercury brand poppet spring.
to make matters worse cylinder 2 plug is damn near black while the others are a nice light brown. Could be my not getting over 6k rpms issue. Coil?
05-27-2020, 10:22 AM #33
Tux u mean replace to replace the impeller? I have the same thing going on as Bunger...
05-27-2020, 10:40 AM #34
The 2 different sizes refer to the diameter of the waterpump base that goes into the housing where the o-ring sits. Older cases had a sleeve above the lower driveshaft roller bearing to pull oil up and lube the upper bearing, smaller dia. The newer cases have no sleeve and an oil passage to lube the upper bearing, larger dia. Everything else is the same except if a 3/4 water tube, then the upper hsg is different.
05-27-2020, 10:42 AM #35
05-27-2020, 10:43 AM #365000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
interesting well my base fit super snug so I’m assuming I have the correct one. I read a threAd on another site about a alpha out drive using a very similar water pump that produces a lot more volume. Wonder if that’s a possibility. New one looked just like the old one I took out.
05-27-2020, 11:00 AM #37
05-27-2020, 12:55 PM #385000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Would I be ok to put .75 head gaskets in it? I have a new set of those and the heads are the only things I haven’t pulled off to check. Wondering if I possibly have a combustion leak let’s gas out and pressurizing the cooling system?
05-27-2020, 05:23 PM #395000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Here’s the plugs. Dark one is cylinder 2(with 4&6 next to it) other pic is opposite bank. Coils ohmed out correctly. They are new plugs maybe I got a dud?
05-27-2020, 05:27 PM #405000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
From post to electrode the bad one ohmed 5050ohms while the other 5 ohmed our to 55-5600. Hopefully that’s my issue
05-27-2020, 05:32 PM #415000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Left bank with bad plug looks cleaner and more “washed” than the other side. Also seeing Unburnt blue oil puddled up on the clean side vs the black oil on starboard bank.
05-27-2020, 07:48 PM #425000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
How come the t stat and housing doesn’t have a tiny bypass or hole to vent air and water before it warms up?
05-27-2020, 07:58 PM #43
Don't need it.
tux974 liked this post
05-27-2020, 08:00 PM #441980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
05-27-2020, 08:03 PM #455000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
High Water Pressure After Changng Water Pump
By maineidyl in forum Technical DiscussionReplies: 8Last Post: 08-11-2018, 05:10 PM -
Mercury Tech: High water pressure & low water temp
By njj502 in forum Technical DiscussionReplies: 158Last Post: 10-19-2017, 03:00 PM -
promax high water pressure
By ActivatedSludge in forum Technical DiscussionReplies: 23Last Post: 10-25-2014, 08:06 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM
