Results 16 to 30 of 88
Thread: High water pressure 225 promax
05-24-2020, 10:30 PM #16
05-25-2020, 12:56 PM #175000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Everything looks good no blown out gaskets or clogs
05-25-2020, 02:59 PM #185000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Put it all back together new gaskets same story. 6 psi at idle on the hose. Verified the gauge. Pressure stays lower with poppet spring cut when I rev it. I guess I should put the new full length one back in? Any other ideas? Runs fine pisses water idled it for 15 minutes never overheated.
maybe I got the wrong water pump in there?
05-25-2020, 02:59 PM #195000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Sierra 18-3319 is the pump I installed
05-25-2020, 03:12 PM #20
did ya split tha adapter plates?
05-25-2020, 03:21 PM #215000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
no didn’t have gaskets for it but the poppet dump was wide open. Same the the dump going from t stats to exhaust. I really don’t think I have a clog because I ran it in January it was fine ran it on the hose in March it was fine then ran it after changing the pump and it was way high
05-25-2020, 03:40 PM #22
05-25-2020, 03:42 PM #235000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Am I wrong?
05-25-2020, 03:53 PM #24
can't commit ona computer!!!..............
05-25-2020, 06:21 PM #255000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
I see there’s two different size water pump diameters? Could I have installed the bigger one? It currently has a Sierra 18-3319. I have a aftermarket poppet not a mercury should I put in a mercury? Should I pull the power head again and tear apart the exhaust plate even tho I blew out all of the passages?
05-25-2020, 06:57 PM #26
You have to split the plates or you have wasted your time. Dumps are in bottom half.
RockTeam Junk
05-25-2020, 07:09 PM #275000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
****. So I guess I need to do that all over again..... not sure what to do. I really don’t think it’s plugged up. I don’t run in dirty water. Unless a gasket blew out in that plate not sure how common that is. I can clearly see the poppet open on the gauge I could ramp up the throttle and the psi would bump up to 10 the n drop to 4-5 once the poppet opened.
anyone know the part number for the exhaust plate gasket
05-26-2020, 06:09 AM #28
PM your phone# and I will send you a pic.
RockTeam Junk
05-26-2020, 05:57 PM #295000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Now I’m 100% out of ideas. Do I need to pull the heads? Exhaust divider? Try another water pump?
05-26-2020, 11:23 PM #305000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Pulled exhaust divider. Everything looked perfect. A little more carbon/oil/spot on one side compared to the other. Not sure what that’s about. Anyways I’m out of ideas. Is it possible I have the wrong water pump on there?
High Water Pressure After Changng Water Pump
By maineidyl in forum Technical DiscussionReplies: 8Last Post: 08-11-2018, 05:10 PM -
Mercury Tech: High water pressure & low water temp
By njj502 in forum Technical DiscussionReplies: 158Last Post: 10-19-2017, 03:00 PM -
promax high water pressure
By ActivatedSludge in forum Technical DiscussionReplies: 23Last Post: 10-25-2014, 08:06 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM -
2000 Promax High Water Pressure Issue
By Big E in forum Technical DiscussionReplies: 9Last Post: 11-09-2009, 04:13 PM
