Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 88
    May 2017
    Ca
    High water pressure 225 promax
    Been chasing this problem for the last few weeks.
    Ran the boat in January everything was fine.
    Ran it on the hose in March everything was fine.
    2 weeks ago did my yearly water pump/gear lube/filters ect to get ready for summer and fire it up on the hose and had 14 psi at idle. Pulled t stats they opened at 143 on the stove. Pulled poppet it all looked fine figured it was the hose pressure causing it. Drop it in the lake and it was idling at 13 and getting 25+ at wot. Definitely seemed to be running rich and cold by the soot on my prop. Also was barely dribbling water at idle.
    brought it home replaced t stats with inverted units recommended by jay smith. Replaced poppet valve assembly dropped lower looked at water pump all looked fine.
    put it al back together fired it in the driveway and was pissing water like normal but idle pressure was still 8-10 and woulnt drop till I revved it. Dropped it in the lake yesterday had 6-7 at idle in gear 10 in neutral and most I saw at wot was 23. Seemed to run fine definitely not overheating. Heads felt evenly warm. Telltale water was warm. Not sure if I just have a kick ass water pump or something else? All lines are clear. Poppet dump passage appears to be clear. Replaced base gaskets and exhaust divider gaskets last year.
    Any ideas because I’m out of em.....
    only thing I haven’t tried was cutting a coil or two off my poppet spring
    Pekin, IL
    High water pressure is often plugged dumps in the adapter plate especially if you have a low water pick-up.
    Rock
    Team Junk
  3. Likes kct11, tux974 liked this post
    May 2017
    Ca
    Quote Originally Posted by rock View Post
    Rock
    Welp it looks like I’m going to be pulling the powerhead then. And yes I have a sport master
    TX......somewhere?
    if ya go ta doin' things that aren't supposed ta be done ya probably gonna "mask" any problem ya havin'...
    its a little over borderline with those pressures sounds like ta me.. know some that would kill ta have that kinda pressure!.. why they would, i don't know.. its performin'/runnin' right?.. not gettin' hot that ya can tell?.. what did it read last year?..
    May 2017
    Ca
    Last year it was 3 to 5 at Idle and 15-ish running it hard.
    TX......somewhere?
    i'd be doin' some lookin' around also then............
    Sep 2007
    bay city mi.
    Went through the same thing. Pull powerhead and clean adapter plate.
  9. #8
    Oct 2010
    Harrisburg,Pa
    Check your gauge, is it going back to 0 every time? What did the old water pump look like?
  10. Likes tux974 liked this post
    May 2017
    Ca
    Quote Originally Posted by perfmarine1 View Post
    gauge appears to be fine. I just bought a pressure/vacuum gauge to check it against my gauge I’ll check it tomorrow. Old water pump was a year and a half old and didn’t look too bad at all. I’m super ocd about not dry starting and keeping the lower out of the sand but last summer my jack plate broke and I tagged a sand bar cause my motor was hanging so low but I ran it 5 times since then and never had an issue.
    May 2017
    Ca
    Quote Originally Posted by kct11 View Post
    eas yours clogged with debris or hard water/calcium buildup?
  13. Likes phillnjack liked this post
  14. #11
    May 2001
    Ga
    Check to see if the plastic sleeve that is pressed in where the poppet slides in and out may have moved out a little . It MUST be even with the block . Hf...
    May 2017
    Ca
    Quote Originally Posted by half fast View Post
    I checked it. It’s solid and peened in place. And I think if it was crooked I’d have low pressure.
  16. #13
    Apr 2020
    Australia
    Had the same problem with mine a few weeks ago and it was the poppet. It had a non genuine poppet valve in it which was slightly different to the one I got from merc. Started again with completely new poppet kit with the grommet and it sat further into the block, also noticed the poppet spring that came out of the promax had a lot more coils (stiffer) than the poppet that I pulled from a 2.5 200. Things to check anyway before pulling the powerhead. Mine was doing the same 25-30psi at 4k rpm and around 12-14 at idle.
  17. #14
    May 2017
    Ca
    Quote Originally Posted by Promaxin View Post
    interesting.... weird cause I had the same poppet in it for 2 years. The new one was an off brand (go marine) I believe. Going to run it with on the hose with 2 coils cut off the spring. I have a complete gasket kit so I’ll probably pull the powerhead regardless
  18. #15
    May 2017
    Ca
    Is the poppet valve even suppose to open at idle?
  1. High Water Pressure After Changng Water Pump
    By maineidyl in forum Technical Discussion
    Last Post: 08-11-2018, 05:10 PM
  2. Mercury Tech: High water pressure & low water temp
    By njj502 in forum Technical Discussion
    Last Post: 10-19-2017, 03:00 PM
  3. promax high water pressure
    By ActivatedSludge in forum Technical Discussion
    Last Post: 10-25-2014, 08:06 PM
  4. Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
    By sasquitch in forum Technical Discussion
    Last Post: 07-31-2010, 09:16 PM
  5. 2000 Promax High Water Pressure Issue
    By Big E in forum Technical Discussion
    Last Post: 11-09-2009, 04:13 PM
