Results 1 to 9 of 9
    Long Beach,Ca.
    water pump melt down
    Uncovered fishing boat to use tomorrow. Noticed things out of place and key on. Used to be nice young kids where I kept it,they grown older and become problems.
    1997 OMC 200 HP
    Water pump housing cracked and melted and impeller toast. All the pieces are there.
    Put new pump in and very little pressure. Check one thermostat and it was clean
    Is there something else that could have melted. Powerhead base or ????
    Sep 2017
    Ashland city tn
    Did u replace ALL parts in water pump ? Did kids start it and let it run a while?
    Long Beach,Ca.
    Yes kids fired it up,no water and total melt down,
    Entire pump replaced.Low pressure and motor gets hot. Will do compression test today to see if more damage was done.
    Will pull lower unit out today and connect hose directly to water intake pipe.
    If I remember right,under power head is a gasket,water jackets, and exhaust deflector. I might inspect them to see if they melted.
    Don't beat the crap out of them, just figure who and tell the police. Everybody needs a quality battery switch.
    Oct 2010
    Harrisburg,Pa
    [QUOTE=wfowahoo;3209468]Yes kids fired it up,no water and total melt down,
    If I remember right,under power head is a gasket,water jackets, and exhaust deflector. I might inspect them to see if they melted.[/QUOTE
    Blow air pressure backwards through water system through water pump tube in case one of the impeller vane got up there
    7 Post(s)
    [QUOTE=perfmarine1;3209518]
    Quote Originally Posted by wfowahoo View Post
    I would of said the same but if no water then no parts could be lodge up there I think.
    Long Beach,Ca.
    impellar had all the vanes...just crispy
    May 2020
    Toledo Bend Lake
    Upper - lower stainless steel plates in correctly? New plastic housing with new stainless liner and of course the correct impeller? Those are the pump internals and externally the connecting pipe to the power head. My FWI - having just gone through the pump rebuild on an 88 hp Javlin. The original housing was melted so just did it all. Had to have run dry for too long to melt the housing.
    Sep 2017
    Ashland city tn
    I think people also fire them up with no water for" split second " to make sure it will start etc b4 they get to water, and if they do that few time over course summer if will melt bottom plate slowly but surely. Just seen that happen alot , also done that myself when I 1st started messing with these things. thought it b ok if it just started and cut it rite off
  1. Replies: 54
    Last Post: 09-23-2019, 11:00 AM
  2. Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
    By tristanlee85 in forum Technical Discussion
    Last Post: 07-02-2018, 10:59 PM
  3. Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
    By sasquitch in forum Technical Discussion
    Last Post: 07-31-2010, 09:16 PM
