Results 121 to 135 of 188
Thread: 1977 Ventura build
04-12-2021, 05:59 PM #121
I used a long narrow 12gal tank laid between the inner stringers, centered between the seat box and the front of the splashwell. THis balanced the boat very well.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
04-12-2021, 08:53 PM #1225000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-13-2021, 07:28 PM #1235000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
So as I get closer to having the entire inside of my boat completely covered in a layer of 1708 what should be the finished layer? Should I cover all the 1708 with a layer of csm for the finish or should I roll on more epoxy to smooth our the mat, I have a bunch of csm left over. I’m undecided if I will paint or gel coat the interior but what ever I do I’m going to give it that splattered look like a lot of guys are doing to give it a texture (grippy) effect. Also will gel coat even work over epoxy?
04-13-2021, 09:31 PM #124
I would think either would be fine.
04-13-2021, 10:48 PM #125
I would add CSM to smooth out the 1708. Gelcoat won't work over epoxy. You'll have to find a different solution. Awl-grip, etc.
04-14-2021, 05:41 AM #1265000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Why is it that gel won’t work over epoxy? The one thing I wanted to gel for sure was the running surface of the boat but first I have to fix all the gouges and and straighten all the strakes and pad. I guess I shouldn’t use any epoxy for this if I’m gonna gel coat it. I could paint the running surface I suppose... the boat will never sit in the water for more than 8hrs at a time. I figured gel on the bottom would be more durable for driving on the trailer and sand bar beaching. If you look back at pics of my boat it is two tone red and white, my plan is to keep it white on the bottom like it already is then paint the red a metallic battleship grey.
04-14-2021, 08:23 AM #127
There's a big debate on this, but polyester over epoxy can have compatibility issues. Some want a barrier coat over the epoxy. West says it's ok over fully cured epoxy but the trick is to figure out when the epoxy has cured enough.
In any case, epoxy is always tougher than gel coat. The first penetration of the core in my boat was at the front of the V where it actually wore through from beaching. I repaired it much thicker than the original and some years later added an epoxy based "rash guard" just to be on the safe side.
Unless you're doing a show boat type restoration, mixing epoxy with thickener and white pigment will work fine to fill the gouges. I used cabosil as a thickener but that can be hard to sand.Living in the Freedom provided by Bud Conner and his fellow warriors.
04-14-2021, 08:54 AM #1285000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-16-2021, 07:19 PM #1295000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Final Layer of 1708 went over my floor tonight, also tabbed in the back side of my rear seat toe kick. I drilled oversized drain holes in my bulkhead, seat box and toe kick, then I filled them back in with thickened epoxy and glassed a small piece of 1708 over the holes, when it hardens I’ll drill them back out with a smaller bit that way no chance moisture will be able to get to the wood. A little overkill I guess...
tnelsmn liked this post
04-17-2021, 03:27 PM #1305000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-17-2021, 03:33 PM #1315000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-19-2021, 07:13 AM #1325000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-19-2021, 08:06 PM #1335000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
What are you guys doing when it comes to protecting the hull number on the back of the boat when sanding and preparing the boat for a different paint color?
04-22-2021, 04:51 PM #1345000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
04-24-2021, 09:12 PM #135-Kevin
1982 Hydrostream Vector
1982 Hydrostream Vamp
1973 Hydrostream Vixen
1977 Ventura II Race Boat For Sale
By JWTjr. in forum Hulls up to 20'Replies: 9Last Post: 09-30-2014, 04:59 PM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
How fast?1977 ventura II
By busa198 in forum General Boating DiscussionReplies: 6Last Post: 03-01-2010, 08:04 PM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM -
Ventura set up ?s
By zzzman in forum Props, Setup, and RiggingReplies: 1Last Post: 11-15-2006, 07:41 PM
