Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 61 to 75 of 188
  1. #61
    May 2020
    Quote Originally Posted by Merc 2.5 View Post
    I tried multiple layers at once , guess u need be kinda quick at glassing, even when I mixed my resin for working time , I still could only get 1 layer at a time , especially around the stringers from what I can tell , practice, practice, practice, until then its sanding and prep for next layer. I did 3 sizes of tabbing and 3 layers 1708 over everything. Overkill always better than to thin etc
    Thanks, yeah I don’t think there’s anyway around it unless you have a helping hand mixing for you and getting what you need. This is gonna take some time, I better get back after it!
  2. #62
    May 2020
    Don’t quote me on this as I have yet to do it but I asked this too and was told you could lay multiple layers up at once to save on sanding. Theres also peel ply which does not require sanding iirc between layers.
    also if you wouldn’t mind would you post up a pic of the bottom of your hull I’d like to compare it to a vandal I just bought.
    keep after it your doing great
    Thanks, gonna be tough to get a good pic with the cradle I built under it in the way. Let me know what angle your looking for. If you go back to the beginning of this thread I have a few pics of the boat out in the open, side profile etc. The Ventura hull looks just like the Action boats of the same era, at least to me it does. Somebody copied somebody. Must’ve been a good design. I have a 1987 Valero V-pad and the Ventura hull is quite a bit different except for the pad area and the part under the transom that’s curved way in by the drain plug.
  3. #63
    Mar 2003
    Belvidere IL, FARM
    What lake are you on in Southern Wis ?
    God, Country, and Fast Boats
  4. #64
    May 2020
    Quote Originally Posted by specboatops View Post
    I’m not on a lake anymore. I grew up on one just outside of Oconomowoc WI.
  5. #65
    Jun 2018
    Floating around
    It looks very similar to my Vandal, your gonna love driving that thing.
  6. #66
    May 2020
ID:	471730Well I’ve been picking away at glassing in the stringers, been real busy with work. Probably gonna be like this for a while, only being able to work on the boat an hour here and an hour there. I knew this was going to happen sooner or later, that’s way I came out of the gate running in the beginning. All I can say is each piece of glass I lay is one closer to the end. What I’m doing is laying 3 pieces of 1708 on each side of the stringers with each piece extending longer on to the hull then the piece before it. When I finish all 3 layers on each side of the stringers I’m going to come back and cap of the top of the stringers with 1 layer of 1708. I no some guys go up and over the stringers with each layer, for a novice like me that’s to much to deal with so I decided to focus on one side at a time. I’m able to get all 3 layers done on one side this way which means no sanding between layers!
  7. Likes LakeFever, tnelsmn liked this post
  8. #67
    May 2020
    I did some more glass work on the boat this past Friday night and Saturday. I woke up Sunday morning with extremely swollen eyelids, I looked like Rocky Balboa. Apparently I have become sensitive to epoxy resin according to the info I’m finding online. Today (Monday) my eyelids are still puffy but improving. I’m going to let this completely clear up before doing anymore work on the boat. I ordered a 3m 6800 full face mask with the pink vapor cartridges. I always wear gloves, face mask, tyvek suit and goggles when sanding. When I lay new glass I only wear gloves and I think the vapor from the epoxy resin is what is irritating my eyes. I hope this full 3m face mask will allow me to continue working on the boat. I read some people’s sensitivity gets so bad that they can’t ever touch the stuff again. Anybody ever experience a reaction like this? Moving forward I’ll be using the new mask and run a fan when laying new glass/epoxy and hope for the best. I figured I run into things that would slow my progress down here and there but never expected this.
  9. #68
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Jmr1974 View Post
    Well that sucks man. My wife was doin those custom epoxy tumblers and became allergic after month or so of doin it and had to stop, she ended up with a epi pen thing just incase. Crazy how that works and dosent affect you 1st time using it. Use good gloves and mask. Don't want throat swell up
  10. #69
    May 2020
    Yeah it sucks, I’m hoping that a full face mask saves my but.
  11. #70
    Jun 2018
    Floating around
    If you rub your eyes with glass dust or get airborne sanding dust from glass in there you get eye irritation. Can’t have too good of a respirator that will probably solve it. I use a versaflo now, amazing technology
  12. #71
    May 2020
    Bet you guys thought I gave up... well I kinda did for a bit but getting back at it again! Click image for larger version.
ID:	482889Click image for larger version.
ID:	482890Click image for larger version.
ID:	482891Click image for larger version.
ID:	482892Click image for larger version.
ID:	482893 Just made the seat box this morning and started the bulkhead in front of it, ran out of plywood. Also picked up a clean clear case yesterday, it just needs a good paint job. So time to order more epoxy resin and hit menards for some more marine plywood.
  13. Likes Hippie459MN, LakeFever, tnelsmn liked this post
  14. #72
    May 2020
    So I’m getting close to bonding my plywood floor to the top of my stringers. I still have to cap off the top of my stringers and glass the bottom of the plywood, also want to brush some gel coat on the area under the floor and on the stringers before I cover it. What is a good way to bond the floor to the stringers? I’m guessing most guys will say thickened epoxy... I’m not sure I can mix enough and get it down fast before it kicks off. Is there another type of epoxy like in a tube that can be used in a caulk gun that sets up a little slower? This way I can skip the part of mixing peanut butter. Also I’m sure any type of fastener (screws) thru the floor into the stringers is a no no in our type of boats...
  15. #73
    You can get empty caulk tubes and fill them yourself. Or even use a gallon bag and cut the corner off. Also get some slower hardener for more time. Epoxy putty is strong and sticky. Weights instead of screws is my go to when possible. You could screw the floor down and after it cures remove them. Lots of ways to do it. If the floor sits tight on the stringers you could lay some strips of very wet glass on the underside of the floor panel and set it into place instead of using putty.
  16. Likes Laseraddict liked this post
  17. #74
    May 2020
    the hardener I’ve been using is 2:1 slow hardener, it still kicks pretty fast when trying to do a big area, it was summer and hot as hell out when I was last working with it, maybe it won’t kick as fast being it’s much colder here now.
  18. #75
    Jun 2018
    Floating around
    This vid here shows a guy piping in thickened resin with a bag. He moves quick, maybe this is will help
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
