Page 2 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 16 to 30 of 188
    May 2001
    Madison, WI
    Setup correctly that speed will be easy. Ask around about setup and weight placement. You are in for a rush! You will feel like your flying. Be carefull
  2. #17
    Minneapolis MN
    Express Composites is based in Minneapolis. Very knowledgeable people there. Carries many core varieties. This is where I've bought all my supplies, easy for me as its a 20min drive. 15 yards of 1708 and 5gal of resin would be a good starting point. Probably want 5 yards or more of 1.5oz CSM also.
  3. #18
    May 2020
    Thanks Tnelsmn, I ended up ordering A bunch of stuff from Jamestown distributors about 2hrs ago. 35yrds of 1708, 7 gallons of resin some cell core and coosa board, I didn’t get any csm... where exactly is the csm used? I see guys mention it all the time in their builds but for what and where?
  4. #19
    Nov 2003
    Portsmouth VA
    Yep, that’s a comp hull. I had a 1976 ventura II comp hull. I ran about 80 with a 150 in-line short shaft and upgraded to a 2 L 175 and moved up to about 87. Both with stock lower units. Boat was set up for ski racing. I glassed a plywood floor between the seat box and the bow compartment to make it more comfortable to drive.
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  5. #20
    Minneapolis MN
    Quote Originally Posted by Jmr1974 View Post
    Chop Strand Mat, it conforms a bit easier than 1708 and has better adhesion, but doesn't have the strength characteristics. I used CSM for bonding the transom boards together, transom to hull, core to hull, and for the final layer over everything to cover any seams of 1708. Also for filling repairs and such.
    I'm no expert, I don't do this for a living or anything. Only just completed my first rebuild. I've just spend countless hours researching and reading before and during my build.
    Also, very cool factory comp hull!
  6. Likes XstreamVking liked this post
  7. #21
    Mar 2016
    cincinnati, ohio
    How did you know that this was a competition hull just from pictures?? Nice catch.
  8. #22
    Callahan, FL
    Looking at the interior pictures, that is how Hydrostream did their comp hulls from the factory, by leaving the taller stringers exposed like that with no flat floor.. And that is a set of their race seats. These hull were raced in the FS class with great success, FS stands for family ski, in which you raced with 2 people in the boat, and the need for 2 seats..
    #12 Miller American SST 140 Tunnel hull
    1970 Glastron Carlson CT-15, Merc 1350
    1977 Hydrostream Ventura II Comp, under construction. Have 1500xs waiting.
  9. Thanks 1954bmw thanked for this post
    Likes CUDA liked this post
  10. #23
    May 2020
    Found out Friday that my materials finally shipped so I have not been able to do anything on the boat, maybe I’ll be able to get after it next weekend. Fingers crossed! So I’ve had a lot of time thinking about the motor for it. Is there any reason to not consider a 140hp V4? I think it would be kinda cool. I really want this boat to hit 80mph without a struggle, is 80 possible with a 140? I know it shouldn’t be a problem with a 200hp but how many more mph does 60hp get? I love the way mercs look but there’s something I really like about the big blocky look of an OMC especially the older V6 OMC’s. I know the 140 looper weighs around 365lbs, probably not much less than a V6 Merc, not sure the weight of a OMC V6 but would like to find out in case I go that route. I know I can get a 140 crossflow that’s in good shape for cheep but they are crankshaft rated with smaller gear case vs the 140 looper is propshaft rated and I think came with the V6 gear case. The crossflow is much lighter tho. I read some older threads from a member here named Laker that knows these 140’s inside and out, hopefully he sees this and chimes in.
  11. Likes Laker liked this post
  12. #24
    Jun 2018
    Floating around
    I loved my cross flow v4 and screamed the hell out of that thing. Premix motor and never had a blip of trouble. Hp was rated at 5200rpm but it spun to 6200 effortlessly. They sound great too
  13. #25
    May 2020
    I’m still interested in the crossflow I found and for the price it might be a fun motor to mess with, it’s looks very clean from the pictures I seen. Might have to physically go take a peak at it on Monday. Decisions decisions....
  14. #26
    May 2020
    Well fellas I guess there’s no turning back now, my stuff finally showed up! Click image for larger version.
ID:	467965Click image for larger version.
ID:	467966Click image for larger version.
ID:	467967I should weigh this pallet before I unpack it, that way I can kinda keep tabs on how much weight I’m adding to the boat.
  15. Likes LakeFever, tnelsmn, Laseraddict liked this post
  16. #27
    May 2020
    Alright, I got my transom boards cut ( 2 layers of 3/4” Cosa board) and a layer of csm for in between. Also gonna put a layer Of csm over the inside of the transom to thicken up the skin before I put my new transom in. I’ve got a couple of ?’s tho, what side of the csm goes against the existing boat shell, the shiny side or the strandy side, same question goes for the 1708 when I get to that. When I laminate the transom boards together should I drill a bunch of small holes in it first to let the air escape? I’ve seen builds on here where it’s done with holes drilled and without...I’m gonna get some pics later, right now I’m sweating my bag off. Also what works best for applying the resin on? I would assume just get a bunch of cheep throw away paint brushes...
  17. #28
    May 2020
ID:	468028 All the materials I had on the pallet weighed 250lbs, so whatever the plastic jugs and cardboard weigh could be deducted from that. I’m not gonna get that crazy tho. Anybody got a guess what the bare bones hull weight is?
  18. #29
    Minneapolis MN
    CSM looks the same on both sides. 1708 will have the shiny side and the "dull" chop strand side. CSM doesn't matter what way it goes. 1708 think of the chop side as having the better adhesion. When I did my transom I put the chop side to the hull, then scuffed the shiny side after it cured with 36g on a DA, then used CSM to to bond the transom boards to the hull.
    Yes drill holes to let air and excess resin escape. I did a 1/8" hole about every inch.
    I've been using .99 paint brushes for applying resin. You'll want a finned roller for working out air bubbles in CSM.
  19. Likes LakeFever liked this post
  20. #30
    May 2020
    Quote Originally Posted by tnelsmn View Post
    I’m gonna drill the holes like you did, just got back from buying a pile of cheep brushes, wish I would’ve thought of the roller while I was there. What’s a finned roller look like anyway? Do you have a pic of it? I’ll have to run and get one in the morning. Thanks.
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
