Page 13 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13
Results 181 to 188 of 188
  1. #181
    May 2020
    So it’s been awhile since I’ve worked on the boat. I’m 95% done with the inside which I will finish but thinking about having a professional do the exterior (sanding, fairing, filling gouges, truing the bottom, whatever else needs to be done exterior and painting it). I just don’t have time for the exterior work, so my ? Is does anybody know of a reputable shop or person that you recommend that will do the work? I’m located in southern Wisconsin, I’d like to keep it fairly close to home but would go further to the right guy. Thanks.
  2. #182
    May 2020
ID:	505029Click image for larger version.
ID:	505030Click image for larger version.
ID:	505031Click image for larger version.
ID:	505032 Finally got back to doing a little work on the boat today. Somebody thought it was a good idea to fill in the pad flat with what looked to me was auto bondo. Hammer, chisel and grinder and back to the pad that’s been hidden for who knows how many years. As you can see I got some work to do on the bottom to get it back to where it deserves to be. The boat lived a very hard life that is for sure!
  3. Likes LakeFever liked this post
  4. #183
    Doesn't look much worse than mine
    May 2020
    Makes me feel a little better. Nobody can appreciate the amount of work that goes into these restores unless they’ve actually been there.
  6. Likes LakeFever liked this post
  7. #185
    Jun 2018
    Floating around
    Quote Originally Posted by Jmr1974 View Post
    ive built a lot if things and nothing has handed me my ass harder than restoring this boat im working on. Its a ton of effort, but it is also so very satisfying at the same time. When eating an elephant you do it one bite at a time. Keep going you got this
  8. #186
    May 2020
    [QUOTE=LakeFever;3343853]ive built a lot if things and nothing has handed me my ass harder than restoring this boat im working on. Its a ton of effort, but it is also so very satisfying at the same time. When eating an elephant you do it one bite at a time. Keep going you got this[/QUOTE getting that bondo of the pad put a smile on my face and motivates me to press on!
  9. Likes LakeFever liked this post
  10. #187
    Minneapolis MN
    Truer words never spoken. They're a labor of love for sure.
  11. #188
    May 2020
    Well I didn’t get as much done as I planned this extended holiday weekend but I am advancing forward.Click image for larger version.
ID:	505490Click image for larger version.
ID:	505491Click image for larger version.
ID:	505492Click image for larger version.
ID:	505493Click image for larger version.
ID:	505494in reality I only worked on the boat for about 3hrs this weekend removing the running surface white gel coat, trying to be very careful not to get carried away and go to deep. I’m going to use a small die grinder to get the sides of the strakes. Another hour or two and I’ll be ready to start fine tuning the running surface. Also picked up 2 cheap spray guns and received my duratec primer. I need to open up the tips on the spray guns…. What drill bit do I need to get them open enough? They only came with 1.4 tips or something like that. Happy Memorial Day!
  12. Likes LakeFever, Hippie459MN, 89LASER, tnelsmn liked this post
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
