Results 136 to 150 of 188
Thread: 1977 Ventura build
04-25-2021, 06:10 AM #1365000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
yes I thought of doing that, I figured if they loosen up on the underside and I go to pull a bolt the nut will fall to the bottom of the seatbox and I will be stuck listening to an annoying nut rolling around under my but. I actually drilled the holes slightly larger just so the teeth on t-nut still could dig in and filled it with PL glue. On the top side I plan to feather them out with thickened epoxy and glass completely over them them, then retap the holes. If they don’t hold up I have some aluminum angle I’ll use to make a rail bracket with heavy duty stainless screws. Actually I kinda like this idea...
Hippie459MN liked this post
04-25-2021, 06:43 AM #1375000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Gonna glass in the foot throttle block today. what a pain in the but figuring out a comfortable place for it, I dicked around over an hour last night moving it back and forth and side to side before setting on where it sits, I have it cocked at a slight angle so the cable won’t interfere with the corner of the seat box. Added some glass under the rigging holes, gonna eliminate them. Don’t see a reason to keep them, I plan to use hydraulic steering and should be able to route everything under the deck and up thru the splashwell delete, plus one less place for water to get in. Also filed in the top of the knees where the rear seat sits so they follow the angle of the seat, didn’t realize this when I made them way back when.
tnelsmn liked this post
04-25-2021, 03:00 PM #1385000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-02-2021, 04:11 PM #1395000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-21-2021, 07:40 PM #1405000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Attachment 487373Anyone know how thick I can go with this fairing compound? I’m using it on my splashwell delete, I should’ve ran my plywood higher than I’d did so now I’ve got to build it up anywhere from 3/8” to 1/4” as it tapers back to the transom to match the sides of the original splashwell... already have 2 layers of 1708 on it.
05-21-2021, 07:50 PM #1415000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-22-2021, 06:40 AM #142
05-22-2021, 07:45 AM #1435000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
so the guy I bought the prop from said he thought it came off a merc, my plan was to get it rehubbed for my OMC. I didn’t realize the splines on the prop would even go on the OMC prop shaft without rehubbing it... in the 1st pic is the sequence of how the washers go without the prop, 2nd pic shows prop on shaft all the way bottomed out on large washer behind prop, 3rd pic shows front of shaft sticking out with the splines. the front washer is to large OD to slide in, do I need different washers for this chopper style prop or do I actually need to rehub it?
05-22-2021, 07:50 AM #144
it should work, just need to find the right thrust washer and use some spacers on the nut side
1973 Viper - sold
1978 Viking - sold
1995 XB02
05-22-2021, 07:51 AM #145
looks like it was drilled out for an OMC already too
1973 Viper - sold
1978 Viking - sold
1995 XB02
05-22-2021, 08:12 AM #146Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
For a 3/8-1/4'' fill job I would prefer to bond down some 1/4'' divinnycell foam. Fair to within 1/8'' and run a layer of 1708 over it. If you want to use a lot of filler, (a gallon?) fair with filler to 1/16'' and cover with 1.5 oz mat.
05-22-2021, 09:21 AM #1475000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
05-23-2021, 07:40 AM #1485000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
How about core cell grid scored? It comes in thicknesses of 1/8” and up, I used core cell for my core. Divinnycell is out of stock like everything else in this world today. I’m not even sure core cell is in stock, it says (limited stock)so I’m calling them tomorrow.
05-23-2021, 07:43 AM #1495000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-06-2021, 12:46 PM #1505000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Haven’t worked on the boat in a month. Ended that drought yesterday.seat box,shifter block and rear seat toe kick are complete with a layer of 1708 and a layer of csm on them. Next I need to finish putting a layer of csm on the hull from the seat box to the back of the boat, from the front of the seat box to the front of the boat the hull is complete. Also need to make a block to mount the battery on.
scott reierson, tnelsmn liked this post
1977 Ventura II Race Boat For Sale
By JWTjr. in forum Hulls up to 20'Replies: 9Last Post: 09-30-2014, 04:59 PM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
How fast?1977 ventura II
By busa198 in forum General Boating DiscussionReplies: 6Last Post: 03-01-2010, 08:04 PM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM -
Ventura set up ?s
By zzzman in forum Props, Setup, and RiggingReplies: 1Last Post: 11-15-2006, 07:41 PM
