Results 151 to 165 of 188
Thread: 1977 Ventura build
06-07-2021, 04:33 PM #1515000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-17-2021, 06:07 AM #1525000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-17-2021, 06:17 AM #153Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Just blast or sand to remove the paint where you will be welding and fairing. Have the welder keep the vent plug cracked while welding on it. It prevents it from blowing out the seals due to oil/air expansion from heat.
06-17-2021, 06:26 AM #1545000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-17-2021, 06:32 AM #155Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Either way works , I prefer welding and then filling with epoxy.
06-17-2021, 06:41 AM #1565000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Also you mentioned just to blast only the area needed for the cone, why not do the whole case and start with a clean slate? I’m not going to match the factory paint, completely new color.
LakeFever liked this post
06-17-2021, 07:47 AM #157Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Blasting completely is ok. You will have to start all over with the corrosion coatings and prep.
06-17-2021, 08:29 AM #1585000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-17-2021, 11:23 AM #159
I used to weld for a living and personally have never been a fan of welding on aluminum after its been sand blasted. I would grind/sand/wire brush if I was doing it. I just used a 60 grit on a 5" grinder to prep mine.
Hippie459MN liked this post
06-26-2021, 04:11 PM #1605000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
06-26-2021, 04:17 PM #1615000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
tnelsmn liked this post
06-30-2021, 07:37 PM #1625000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Did my first coat of fairing on my splashwell delete tonight and some other miscellaneous spots like old rigging holes. I’m using a 2part fairing compound called total boat, total fair epoxy fairing compound. I’ll let it harden up over night then give it a sanding hopefully tomorrow and see where I need to add more.
07-06-2021, 07:39 PM #1635000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Still working on the splashwell,getting pretty close with that and the old rigging holes. Also started sanding the red paint off to get to the old red gel coat. I’m using a 5” orbital sander with 80grit to sand off the paint, should I stick with the 80 or go a little more aggressive on the grit? With the 80 I can watch the paint disappear and then the primer shows and then I get to the gel coat, this takes awhile with the 80grit but allows me to be careful not to go to deep into the gel (less fairing to do later). Everything above the rub rail has been painted and I believe everything below the rub rail is just faded gel coat.
07-07-2021, 06:14 AM #1645000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Anybody got an opinion on weather I should stick with 80grit on the orbital sander to get rid of the paint and primer or should I drop down to something like 60grit to speed up the process?
07-07-2021, 06:49 AM #165
Many guys have success with paint stripper for this if the sanding is a pita. In auto body work for paint sanding we used 180 and jitterbug sanders. Ingersoll Rand makes a good one takes a half sheet. Gel goes on an 80grit finish so it might be best to stick with the 80 if your going to keep sanding it off. The speed of 60vs80 for cutting down paint would be minimal imo
1977 Ventura II Race Boat For Sale
By JWTjr. in forum Hulls up to 20'Replies: 9Last Post: 09-30-2014, 04:59 PM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
How fast?1977 ventura II
By busa198 in forum General Boating DiscussionReplies: 6Last Post: 03-01-2010, 08:04 PM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM -
Ventura set up ?s
By zzzman in forum Props, Setup, and RiggingReplies: 1Last Post: 11-15-2006, 07:41 PM
