Results 1 to 12 of 12
Thread: Big bore crossflow rebuild
05-23-2020, 01:49 PM #1
I am rebuilding a 1990 Evinrude XP175. #3 piston badly scored, and the rest just scuffed. Ended up boring 5 holes at .030, and the #3, at .040 over. The block was already at .020". The pistons that I ordered are cast WSM, with rings, and pin. I haven't found much information on here about the WSM. Any opinions, or set up tips?
This engine came with 638/39 heads, also. Thanks.91 Seaswirl 178 spyder sport. Evinrude XP175. (59 MPH, so far, and so close).
85 Sleekcraft SST , 225 Johnson...(sold)
05-24-2020, 06:17 AM #2
Wsm is a great product, havent heard of a piston failure yet
05-24-2020, 10:27 PM #3
Cooling system must be at 110% for this motor!!!! Sleeves way to thin..
05-24-2020, 11:53 PM #4
Are the ports plunge milled or CNCed? So I guess it has no scallops in the pistons and coinciding relief cuts in the block?
You have the best heads. What carbs?
05-25-2020, 03:51 PM #5
I am having my OMC guy assemble the block/crank,etc. Here is a picture with the #3 cyl. cover removed. Looks like a hairline crack between ports. Those sleeves will be thin, but whadda gonna do. Just an old Flow, on the stock,(5,800), limiter. The carbs are stock 1-3/8" with 63C jets, (stock is 61C). I have some 65C jets I could use from my GT150, to start with.
Has a Bob's nose cone, low water pickup. I will with start with a fresh impeller, also. Using it on a 91 Seaswirl ski boat, just to buzz around a little.91 Seaswirl 178 spyder sport. Evinrude XP175. (59 MPH, so far, and so close).
05-27-2020, 05:21 PM #6
Those are plunge milled. Unless you want to spend sometime on them squaring them off, it will run fine. With that boat, I would bother with it. I usually use larger mains on break in. Just don't put too much timing in and premium fuel only and you'll be good.
05-31-2020, 01:34 PM #7
What's wrong with my boat? OK, I agree. I'm going to give it a shine this month, though. The WSM pistons came in, but my OMC guy turned up his nose at them. I guess we are supposed to run Wiseco.forged.
I hope the boring guy kept it right at 3.625+.030=3.655" , and #3 cyl.at 3.665". The +.030 pistons measure 3.6486". If the machinst thought it was getting wiseco's, it might be a couple thou big.
05-31-2020, 09:05 PM #8
Ummm. If its machined for seizcos then use them , ( I think they alot better now days) if bores r correct and good good break in , but dont knock the wsm. Just sayin
05-31-2020, 10:01 PM #9
I won't be happy if it was bored for wiseco's. I'll be stuck with $500 worth of WSM ashtrays, and I don't smoke! I am keeping my eye out for another big bore block, or complete 20" 175-235 flow, etc. But first I'll wait and get the results on my piston clearance. I still have a 91 Johnson GT150, with a good powerhead, but the rest got torn up pretty good from a submerged log... . I need to make it complete, as a spare. Why am I spending time, and money on all this old stuff? It's the principle now. Breaking equipment, and not making right again feels like a personal failure, even though it probably doesn't make sense to most people.
06-01-2020, 10:17 AM #10
06-02-2020, 07:58 AM #11Scream And Fly VIP
- May 2001
- Hickory NC
- 5,579
- 18
- 248
- 203
- 462
- 4 Post(s)
If he bored it to 3.665 it is way too loose for a .030 over piston no matter what brand. That size needs a .040 over cast.
06-02-2020, 01:29 PM #12
Number three cylinder, ( the bad one), was bored .040 over, and the rest cleaned up at .030" over. The block was already at .020". The .040 piston measures 3.6587".
I should have mentioned that one .040 piston in my earlier post. I haven't heard anything about how they fit, yet.91 Seaswirl 178 spyder sport. Evinrude XP175. (59 MPH, so far, and so close).
OMC Big Bore Crossflow Pistons
By HydraSport179V in forum Parts WantedReplies: 12Last Post: 06-12-2018, 09:01 AM -
Rebuild Kit for a 200 Chrome Bore
By Steve200 in forum Technical DiscussionReplies: 6Last Post: 03-20-2017, 10:48 AM -
L&S big bore carbs for a crossflow
By B.Leonard in forum Technical DiscussionReplies: 5Last Post: 04-22-2004, 10:21 PM
