Results 1 to 15 of 34
Thread: Sportmaster
05-22-2020, 07:28 PM #1
Sportmaster
So I have a chance to get a sporty very very cheap, the catch is , guy said it mite had froze or sumthin and pushed prop out , so it stripped threads for carrier , can the threads b fixed? Or can a carrier be pinned?
05-22-2020, 10:24 PM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
yes there is a man in Florida who does a bang up job( cannot remember his name) seems like it was around 350? 400 to redo the threads that may not be right either not my favorite case though i have have several in the last decade and a half for my 20XD got to run it to high to get something cooking!!! ive been running a torqmaster with my own cone on it for a good long time keep in mind if it pushed carrier out most like rusted the guts not sure how bad its a gamble any way you look at it
tux974, Dave Strong liked this post
05-22-2020, 10:42 PM #3
The Aluminum Doctor. He fixed a couple sporties and a few CLE's for me a few years ago. Did a good job and the turn around was relatively quick. Dunno if he is still around down there.
tux974 liked this post
05-23-2020, 05:57 AM #4
For sum reason I hear sportys goin down alot more often than anything else ??
I can get it so cheap that I think it's worth a shot if case isnt busted or anything , the guy took it to a mechanic long time ago, he said they said , the gears and stuff looked to be in good shape but I dont know anything else. I'll go look and take couple pics after holiday
05-23-2020, 09:40 AM #5Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
if its apart can u take pixs of gear numbers and prop shaft?? consumer gears can be loaded into any case if you know how i bought one off here years ago that had consumers in it with no way to drain oil unless it was turned upside down and water pump base was removed or carrier was removed then filled up thru water pump base opening what a pita i had to fight to get my money back
LakeFever liked this post
05-23-2020, 11:39 AM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
05-23-2020, 05:32 PM #7
It's not apart but from what I hear I can prob almost just slide carrier out. hes at cabin for weekend but when he comes back mon I'll go check it out and get pics , possibly a cle but he said sporty , I havent seen it yet
05-24-2020, 04:45 AM #8
The Dr has done quite a few for me and always done a good clean job with a reasonable turn around time.
06-14-2020, 05:33 AM #9
So I ended up getting the sporty , it's a 1.87 straight skeg with built in tab everything looks to b in decent shape. It looks like it just pushed the threads to rear of the case. Anyone seen that b4?
06-14-2020, 06:17 AM #10
I just came out to look at the threads , and I'm not sure that's the prob. Is this thing missin lock ring and stuff to hold carrier in??
Nothin looks tore up. Looks like its just missin carrier nut. He said last time it was in water ,it didnt wanna go in gear and when he put oil in it he seen carrier move outward, well if it dont have the nut on it then all that makes since , threads r still there
1 more thing , there carrier does not look like it turned at all , keyway still there and locked in ,Last edited by Merc 2.5; 06-14-2020 at 06:59 AM.
06-14-2020, 01:06 PM #11
06-14-2020, 01:27 PM #12
06-14-2020, 01:46 PM #13
06-14-2020, 02:37 PM #14
Cant I get the bigger nut or double them up and get fresh thread. or am I pissin in wind
06-14-2020, 02:45 PM #151980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
250R 300R Sportmaster vs 3.0 Sportmaster
By xb03fs in forum General Boating DiscussionReplies: 21Last Post: 07-13-2018, 06:54 AM
