Results 1 to 7 of 7
    Sep 2009
    Miami
    Mounting Garmin GT51M-TM on a stepped transom side vu,down vu, chirp
    Mounting transducer on a 21 Action Marine Center Console. Trying to find the best place to mount. Seen a few pics of mounting on the step. Pic attached for reference. Click image for larger version.
ID:	466057Thanks in advance.
    Tom
    Jul 2011
    Gloucester, VA
    Will work great at idle speed. Won't at anything above
    Sep 2009
    Miami
    Pic of my transom. Was thinking if not off top of step, between drain plug and blue tape.
    Jul 2011
    Gloucester, VA
    Id go at the blue tape. It will read at all but real high speed. (Asumimg you get on the pad and lift it out the water) They say don't put it that close to a chine but it will be good. I install a few a month.
    Jul 2011
    Gloucester, VA
    And get the spray shield. These long ass transducers throw an insane amount of spray
    Sep 2009
    Miami
    Thanks. I was scared of the dreaded chine. But looked like a perfect place. Do you believe in the 1/8 below hull rule?
    Tom
    Minneapolis MN
    What about a through hull transducer? Or are those limited for options?
  1. 1988 Don Aranow 24 cat stepped hull and transom
    By kkj9798 in forum General Boating Discussion
    Last Post: 01-23-2013, 06:36 AM
  2. OMC Tech: transom mounting jig
    By jerry1865 in forum Technical Discussion
    Last Post: 01-19-2010, 05:06 AM
  3. Flush Mounting a Garmin 176C GPS?????????
    By jeffbare in forum Technical Discussion
    Last Post: 05-25-2009, 08:29 AM
  4. transom mounting bolts
    By David in forum Technical Discussion
    Last Post: 08-30-2005, 08:27 PM
  5. Transom Mounting Hole Pattern
    By Howard Daenzer in forum Technical Discussion
    Last Post: 12-25-2001, 10:23 AM
