Results 1 to 1 of 1
05-17-2020, 08:10 AM #1Junior Member
- Oct 2017
- Port St Lucie
- 11
19' 1990 Stratos Fish/Ski 1991 Merc XR-6 150/hp Turn Key $3250 - Brevard County, FL.
https://spacecoast.craigslist.org/bo...121766963.html
321-287-7735
The boat has newer:
- rear floor from marine ply and epoxy resin
-all new carpet i put in in 2018
-all new wiring, new stereo with blue tooth, 2 6x9's, 2 8's" and 2 6's"
-brand new batteries 2 months old.
-two new bilge pumps (one the far stern, 1 in ski box i added).
-has bat switch
-has twin bat charging solenoid to charge both bats at a time.
-has CB radio
-has 2 fire extinguishers (in good cond).
-has brand new shift cable (2 months old)
-has newer Teleflex Manual Steering Setup installed 2018
-newer rear seat built (very sturdy) and all new upholstery (some rust spots from bolt mounts).
-newer folded ladder and bracket/ladder fits in ski box.
-has an older fishfinder installed and working.
-has 2 battery monitor LEDs installed and working
-has a siren/warning for high water installed but not hooked up
-has 3 light switches 1st for two white led's, 2nd for dash lights, 3rd for four blue LEDs (all inside cabin)
-has newer gauge cluster (1 combine gauges and 1 tac)
*Tach is pretty consistent but does drop to 0 and then back up.
*Fuel Guage ditto/checking connections today...
-has a purple bimini top from prior boat/nice when it's sunny out.
-has a 4 blade SS performance prop
-has Hot Foot for throttle
-has single Shifter for F/N/Reverse
-New Shifter Cable and install bracket.
-Brand new boat cover also included.
In 2017/8 I put some time and money into this boat......!
Motor is a 1991 XR-6 Merc 150hp 20".
-Outboard is a Premix only (you must pre-mix oil and fuel manually) this is done to safeguard blowing it up.
-runs on a manual jack plate for better everything.
The boat does "Get Thirsty" and will drink some fuel if you are running hit hard.
The fuel tank is like 25gallons and you can burn thru that in a few hours of running it hard.
Boat Prop is stuck with the lower unit/it will not come off.
The boat originally came with a Johnson 175 but i switched it to a mer after blowing GT.
Current merc runs great, fires right up after sitting for months.
Took it out this weekend (May 9th) and will again before it sells.
Video on YouTube of it running here: https://www.youtube.com/watch?v=UE9p__JgOYw
Trailer is in very good shape with non-rusted anything.
Newer boards and carpet in 2018
Great tires, hubs, and bearing buddies.
Lights work.
Has older spare tire.
This is a Freshwater or Salt/inter-coastal only boat.
The draft is very low so it runs shallow and also the boat sits very low in the water as well.
This boat does "ok" in semi chop waters but you "must drive it"...
Have pulled 62MPH on Cell phone GPS solo..
NOTE - this boat does Not have Hydraulic Steering and unless you are familiar with this i would not suggest this boat to you. This boat runs like a Go-Kart, you feel the turns, you must "Drive It" or it will Drive You - Right overboard. It does "Track" well Straight but you will always need to have 1 Hand on the wheel at all times.!
The boat has two fishing pole holders and a ski pole setup but I covered it up with upholstery.
Merc 2.5 200 Promax w SVS $3250
By T-racer in forum Outboard EnginesReplies: 1Last Post: 01-11-2019, 06:58 AM -
1991/1996 Stratos 295 Pro Silverstar
By hometown45 in forum Hulls up to 20'Replies: 1Last Post: 04-09-2018, 07:53 PM -
Stratos 486SF (2007) Fish n Ski
By M.CHAPMAN in forum Hulls up to 20'Replies: 2Last Post: 03-21-2015, 09:43 AM -
BRevard / Volusia / Idian River county get together????
By Tom Smyth in forum General Boating DiscussionReplies: 49Last Post: 11-15-2012, 11:12 AM -
Mercury Tech: V200 0D014632 merc, 1990 or 1991?
By wbones9 in forum Technical DiscussionReplies: 2Last Post: 03-08-2009, 02:45 PM
