Results 1 to 12 of 12
    Aug 2018
    On a racetrack or at the lake
    300 ProXS vs 300R actual hp
    I don’t understand how Don can say there’s no reliable dyno difference, how are the CARB reports not reliable as manufacturers are certifying them for emission purposes which I would think carries a lot of weight? He requires everyone to post their serial # in a thread which I assume is because Mercury is wanting to track things or is there another reason he wants that info if he doesn’t get paid by Mercury to monitor the forum? It’s not rocket science that the engine with a higher rpm efficiency because of a different cam and shorter intake runner is going to make more power. If the 300R pushes the limits of the 10% rule then the 300ProXS can’t as well and the CARB report shows it makes 20hp less at a lower rpm.
    http://www.bbcboards.net/showthread.php?t=1055079
    Oct 2009
    Gonzales, La
    Here’s another one:
    http://www.bbcboards.net/showthread....=#post10700764
    I’m not sure why Don is so against the carb power and torque numbers. I get the impression he’s a bit of a control freak, to say the least.
  3. Likes rob@sportsmancenter liked this post
    Jul 2011
    Gloucester, VA
    His way or the highway. He makes good koolaid
    I love when he gets on his "I'm the only person in the world that can clean optimax injectors" kick...
    I see so much **** that he posts that is just plain wrong. Especially with the new V6 and V8 motors. No point in arguing though. The nut swingers have his back.
    Oct 2009
    Gonzales, La
    Apparently he offers really good pricing on merc extended warranties but I just cant bring myself to do business with the nazi.
    Nov 2019
    Canada
    I can't believe anyone is even listening to that guy flap his gums....
    www.InjectorService.com
    Call/Text - 204-326-0390
  7. Likes RSWORDS, Merc 2.5 liked this post
    Gothenburg, Sweden
    Who is Don?__PRESENT
    Feb 2017
    Wixom lake michigan
    Hes the guy who deleted my posts when someone asked what oil to run. My reply was simply to email mercury, as they were very helpful and quick to respond. For some reason he didn't like that?
    Oct 2009
    Gonzales, La
    There was a question about vesselview and how the fuel level worked. I explained that it will actually work without a level sender but you have to input the size of the tank and enter the amount when you add gas. He PM’d me and said I was spreading false information and he deleted my posts. I explained that it does work and I can prove it with screenshots. He didn’t respond or put my posts back. He’s also deleted my posts showing the CARB power and torque ratings of outboard engines, which of course were fully referenced. And then there’s the constant threats when people dare post questions, even general ones, without posting their engine serial numbers for the world to see...
    Sep 2017
    Ashland city tn
    I was talkin to a guy bout a prop over there , and erased ALL my post and sent PM said if I didnt have my email available for world to see then I couldn't post. Douche
    Oct 2009
    Gonzales, La
    Yes, he won’t let you post anything (even responses or inquiries) in the classified section unless you post your email address. Forgot about that.
    Jul 2012
    Lufkin, Texas
    i don't have anything to do with "bbc" in any of its possible references other than "big block chrysler" or "big block chevy." I'll leave the "bass boat central" and the "big black ۥۣ" to Don and the rest of you guys...
  14. Likes rob@sportsmancenter liked this post
    Sep 2017
    Ashland city tn
    I use it for props if I'm needing a thru hub
  1. New 450R's and 300R's and 300 ProXS Motors
    By WILDMAN in forum Outboard Engines
    Last Post: 10-31-2019, 10:06 PM
  2. Actual weight of mercury 300r
    By WILDMAN in forum General Boating Discussion
    Last Post: 04-06-2019, 01:33 PM
  3. Replies: 24
    Last Post: 12-26-2018, 09:32 AM
  4. Actual U.S. Unemployment: 15.8%
    By Steve 1 in forum The Scream And Fly Lounge
    Last Post: 05-10-2009, 01:09 AM
