Results 1 to 7 of 7
Thread: Sealant
    Sep 2019
    madison wisconsin
    Sealant
    I am going to be installing a jack plate on a figerglass hull what is the recommended sealnt to use on the bolt holes . Should I smear sealant covering where the jack plate touches the transom? I have seem 5200 and silicone and every under the sun. Just want to do it right
    May 2001
    Maine
    5200 is a good choice if you never EVER want to remove the jack plate as its a adhesive as well as a sealant. On a Baja I owned with a jack plate that (I had professionally installed) there was a small bead/lip of sealant around the entire plate where it touched the transom which I believe was the result from covering the entire plate area like you referenced. I am not sure what type of sealant was used but it was fairly hard like 5200 but was clear, I do know it wasn't the normal water resistant rubber GE silicone from Home Depot. Not sure what color your hull is but last I knew 5200 didnt come in clear so you may not want the white lip from 5200 around the plate if you go that route. I am sure someone will chime in with the name of a clear product.
    Mar 2004
    Brooklyn Park, MN
    4200 works well.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    upstate N.Y.
    IMHO 4200 , 5200 is forever !!!!
    why ask me ?
    Jun 2002
    Northern Utah
    Yep, 5200 has been called gel coat remover
    Feb 2011
    HUDSON, FLORIDA
    put a small circle around each hole on hull, and on bolt , avoid threads. if you go around whole plate, you can trap water between the two, not good.
  7. Likes TEXAS20225 liked this post
    Apr 2016
    Victoria bc canada
    Use sikaflex 291... mounted and repower hundreds of engines without a single issue.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
  1. Sealant for pop up cleats?
    By Matts94z28 in forum General Boating Discussion
    Last Post: 08-05-2013, 07:48 AM
  2. Sealant...
    By JAYROCK in forum Fiberglass and Composites Discussion
    Last Post: 02-18-2006, 09:59 PM
  3. Which sealant?
    By angleiron4 in forum Props, Setup, and Rigging
    Last Post: 01-27-2005, 02:56 PM
  4. Crankcase sealant???
    By GatorBaiter in forum Technical Discussion
    Last Post: 07-11-2003, 08:23 AM
  5. Sealant Question
    By gwalt584 in forum Technical Discussion
    Last Post: 07-01-2003, 08:17 AM
