Results 1 to 2 of 2
    Apr 2018
    Niagara Falls
    testing CDM procedure question
    I am trying to test the CDM,s for my 2000 200EFI using the mercury manual, but i am a little confused by the procedure. the page shows the CDM but it isnt specified if i am testing the coil leads with or witout the the wiring harness hooked up to it?
    is it a "must" that i have the CDM test harness for this procedure?
    and im also assuming that my KLIEN digital meter isnt going to work; i need an analog DVA meter (or a dva adapter)?
    after fooling around, im guessing i need the test harness, the harness connected and i need a DVA meter...
    Karl
    Apr 2018
    Niagara Falls
    Also, for those who are pro’s; Instead of paying $80 for a harness, can I simply make an extension with the test leads?
    i ordered a meter and harness, along with the merc flywheel puller
    Also found the wires on the trigger were deteriorating so ordered a new one. I clean the engine compartment a few times a year to inspect wires and connections but until now the coating appreared to be ok, it’s falling off and wires are green and also coming apart.
  1. I'm not getting the warning horn test beep. Question about testing horn.
    By Bumblebeeman in forum Technical Discussion
    Last Post: 04-03-2020, 10:51 AM
  2. Video: CRT Testing Stock F1 today! Testing modified F1 on Saturday!
    By caldwellrace in forum General Boating Discussion
    Last Post: 03-26-2020, 01:11 PM
  3. Break-in procedure
    By 2fast4mom in forum Technical Discussion
    Last Post: 01-25-2004, 11:43 AM
  4. Starting Procedure Question
    By Carter Powell in forum Technical Discussion
    Last Post: 09-30-2003, 09:37 PM
