Results 16 to 30 of 43
05-15-2020, 04:45 PM #16
Whos cranking them plugs in like enough to strip threads
05-15-2020, 05:45 PM #17I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
powerabout liked this post
05-15-2020, 06:02 PM #181980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
Instigator thanked for this post
05-16-2020, 08:50 AM #19
I have a 4.6 in my truck and a 6.8L Triton V-10 in my motorhome. My friend at NAPA asked, do you want the tool now or would you rather come back and get it ???
Out of 18 plugs, I broke …. none. A couple I was worried about … but the whole thing came out as one piece ..
This is what I was warned .. would / could happen … >
Scream And Fly liked this post
05-16-2020, 09:35 AM #20
@bill mason , I just wanted to say hi Hope you're well buddy.
05-16-2020, 10:57 AM #21
Thout we were talking boat heads ,i changed my plugs in my ram at 75 k put in fine wire ngk to hope never do it again its at 166 k now runs fine yet truckmis 15 yr old lots of rust so i,m good
05-16-2020, 04:29 PM #226000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 155
Thanks Chaz for the pic's of the enemy(spark plugs). I too have a motor home with the V-10. 30,000 on a 2004. I'm not looking forward to replacing the plugs.
Gary
05-16-2020, 06:05 PM #23
Here's the title .. make of it what you will :
Unless your boat is swinging from davits behind you home on the water, your truck is a very important tool in boating ..
gfinch
They are a weird bird indeed .. one balance shaft up top . Plugs that go in thru the intake face .
Chamber quench area (what little it has) is on the "wrong side" of the head. But by doing so, they were able to stand the intake valve and port all most straight up . That and with the peanut sized exhaust port .. they make (as you know) a mountain of torque off the bottom and mid range cruise.
What I did with mine was gunked the engine down, blow any remaining road grime off. I pulled the wires off, shot PB Blaster in the holes put the wires back on , let it run for 30 - 40 seconds to try and expand the aluminum ( I doubt it did anything but make me feel a little better) broke the plug loose ,, worked it back and forth a little .. then turned them out.
I kind of went about it with the mind set that if I took my time and keep side loading to a minimum .. that I would only break a few. I guess I got lucky that I didn't have a lot of rust / carbon on the lower body portion of the plug.
Should fit a Verado mid .. standing on end ...
05-16-2020, 07:03 PM #24Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Warm it up some and just pull them plugs with an impact gun.
05-16-2020, 08:15 PM #257000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Hi Gary - Like this? https://www.amazon.com/Powerbuilt-64.../dp/B0014FGVVW They work well when someone has started to crossthread a plug and buggered the first thread. Similar results to pulling the head and running a tap or chaser in from the chamber side. Much easier.
But not going to help if all the threads are gone.
Instigator liked this post
05-17-2020, 02:11 AM #26Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-17-2020, 06:31 AM #27I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
05-17-2020, 06:34 AM #28I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
05-17-2020, 11:15 AM #29
Ifin you were ever on the road for months at a time , 1500 miles from home and found yourself in the pits , WalMart parking lot , etc , needing to change a few pistons , a tuliped exhaust valve .. or even just a burned head gasket … you would appreciate the importance of a two piece pan , dry sump oil pump , front mount distributor and of course , push rod's …
The next race or two would be over before you would get this engineering marvel apart , repaired and back in one pile ...
Then my favorite , the late model cam phase gear ...
What do the "experts" think of cam chain guides ...
Chaz = thinkin , you'll never get 1.125" of lift , 400 lbs on the seat and 900 over the nose with this set-up ..
05-18-2020, 07:51 AM #30Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
pushrod engine is the way to go but I can do without a distributor, then its real simple on the road maybe even a Duramax??
stripped out spark plug hole
By cocacola in forum Technical DiscussionReplies: 8Last Post: 05-24-2019, 05:17 AM -
how to repair an already repaired spark plug hole
By Tom Smyth in forum Technical DiscussionReplies: 5Last Post: 12-31-2015, 08:07 AM -
Stripped spark plug head fix?
By FlowMaxx in forum Technical DiscussionReplies: 15Last Post: 10-22-2014, 06:55 PM -
stripped spark plug hole
By 1bad67 in forum Technical DiscussionReplies: 10Last Post: 05-20-2006, 11:08 AM -
150 stripped spark plug hole.......
By rookieflyer in forum Technical DiscussionReplies: 13Last Post: 09-08-2002, 08:46 PM
