Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
    Loudon Tn
    stripped spark plug hole - can it be repaired other than help coil?
    Not enough thread to hold heli coil. Can head head be heliarch welded and new threads tapped into it? Or any other fix?
    Stay healthy have fun
    Sep 2017
    ontario
    Time sert seems to be the fix from my look see . Give them a little read on the forum that comes up below this thread
  3. Likes rgsauger liked this post
    Mar 2004
    Durham Ct
    Drill and tap it 1/4" NPT. Screw in a brass pipe plug or reducer fitting really hard. Maybe a dab of green Loctite. Mill it off flush on both sides. Drill and tap it 14mm. Used this method to fix a bunch of the old Mercury "Stock Outboard" racing motors.
    If you weld it, you take the heat treat out of the aluminum. Goes from T-6 to T-0 (dead soft). Not what you want on a race motor. Any kind of insert will act as a glow plug, because they are made of some form of steel and don't transfer the heat like aluminum. Brass transfers heat very similar to aluminum.
  5. Likes rgsauger, tnelsmn, Instigator, loop liked this post
    Feb 2020
    Alabama
    Time sert worked well for me more than once.
    My current boat has 2 cylinders running them.
  7. Likes rgsauger liked this post
    Time Sert
  9. Likes Forkin' Crazy liked this post
  10. #6
    Quote Originally Posted by mike schmidt View Post
    Well lets apply some basic's here :
    The correct bit for 1/4" NPTM is .4375 or 7/16"
    The correct bit for 14 x 1.25 mm is .500 or 1/2"
    It seems to me that all the work you do to put in a plug would go to waste when you drill it all out, or in the case of a stripped plug hole .. the 1/4 NPT tap would fall thru the hole before you even get started …
    Those of us with ADD shoot the hole .492 with a bit and ream the final size to .499 and wind up with tight threads because of the tap used. Do your homework on taps , you'll learn why that is ..
    I would also suggest that you buy a cheap spring loaded center punch .. and Ka-chink some actual T-6 material .. and then some outboard head and block castings to see the difference.
    Out of the literally hundreds and hundreds of sparkplug holes I have welded , not one has ever pulled the threads out from being too soft .. I think the problem is not being able to weld a hole shut that has the same depth as diameter and keep the air pockets out ..
    Think the seats fell out after welding the bores …
    The studs pull out of this 911 Turbo head after welding the floors ..
    How much heat do you think it takes to close these chambers up ..
    How many plug holes failures do you think these heads have had …
    Do you think this step turned "dead soft" and broke the first time someone stepped on it .. ???
    I can go on and on …
  11. Likes Dave Strong, Scream And Fly, rgsauger liked this post
  12. #7
    8 Post(s)
    I thnk lots of plugs stripped because the heads were not hard as they should have been in the first place
  13. #8
    Loudon Tn
    Thanks for quick reply guys. Much appreciated.
    stay healthy have fun
  14. #9
    Put down the half inch breaker bar and buy a quality inch/pound torque wrench … you'll be amazed at how much better the aluminum has become …
  15. Likes Dave Strong, sonicss33, rgsauger liked this post
  16. #10
    That old 1/2 turn after finger tight on gasket plugs only applies to the first time.
  17. Likes Instigator, David - WI liked this post
  18. #11
    Quote Originally Posted by Dave Strong View Post
    That must mean on a used plug … ya go a full turn …
  19. Likes Dave Strong liked this post
  20. #12
    Nov 2019
    Canada
    The nice thing is once you've gone full turn once, it is easy to go full turn again!
    www.InjectorService.com
    Call/Text - 204-326-0390
  21. #13
    7 Post(s)
    There is also a new tool out that goes through the plug hole, then expands to cut threads as you extract it and the shavings to be able to do one w/o pulling a head.
    Probably designed for the new hi tech car motors that are so labor intensive.
    Like a grand to put a water pump on a new Ford 4 or 6 banger!
    I think 8 or 9 hrs flat rate!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  22. Likes specboatops liked this post
  23. #14
    Had those when i was at GM, special Cadillac and Corvette special tools. This leaving plugs in an aluminum head for 80k is nuts, threads tend to come with the plug.
  24. Likes gfinch liked this post
  25. #15
    Cudjoe Key FL
    I think what you talking about is “Lock Stitch”. It is the only method approved by Ford for warranty repairs on the spark plugs that blow out. The proper alloys match the Ford heads and expand and contract at the same rate.
  1. stripped out spark plug hole
    By cocacola in forum Technical Discussion
    Last Post: 05-24-2019, 05:17 AM
  2. how to repair an already repaired spark plug hole
    By Tom Smyth in forum Technical Discussion
    Last Post: 12-31-2015, 08:07 AM
  3. Stripped spark plug head fix?
    By FlowMaxx in forum Technical Discussion
    Last Post: 10-22-2014, 06:55 PM
  4. stripped spark plug hole
    By 1bad67 in forum Technical Discussion
    Last Post: 05-20-2006, 11:08 AM
  5. 150 stripped spark plug hole.......
    By rookieflyer in forum Technical Discussion
    Last Post: 09-08-2002, 08:46 PM
