Results 1 to 5 of 5
05-11-2020, 01:22 AM #1Junior Member
- Oct 2019
- Finland
- 28
OMC Johnson 225 no rpm signal and not charging
Hi!
So my old Johnson 225 V6 is not charging and dont give any signal to rpm meter. Changed first rpm meter because it is old and not working and then find that it is not giving any charging either. Have read that high possible problem is in rectifier...
I have Powerpack 586662 24 C1D-BA in my motor. Anyone can advice what is the correct rectifier? Ignition is very good and it will start very nicely.
-Antti
05-11-2020, 06:38 AM #2"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
racer liked this post
05-20-2020, 11:37 PM #3Junior Member
- Oct 2019
- Finland
- 28
05-21-2020, 08:31 AM #4Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
make sure you use a wet cell battery and the terminals dont have wing nuts, those 90 degree looper charging systems are very fussy
05-22-2020, 07:32 AM #5Junior Member
- Oct 2019
- Finland
- 28
No tach signal
By bado300x in forum Technical DiscussionReplies: 1Last Post: 05-09-2020, 12:47 PM -
OMC Tech: 1993 johnson fast strike not charging
By seef158 in forum Technical DiscussionReplies: 7Last Post: 07-20-2015, 08:05 PM -
260 tacho signal
By Sjefen in forum Technical DiscussionReplies: 1Last Post: 03-09-2015, 03:54 PM -
2.4 Tach Signal?
By redpickle in forum Technical DiscussionReplies: 7Last Post: 03-29-2014, 04:07 AM -
Warning signal??? Maybe ecm??
By Powmer in forum General Boating DiscussionReplies: 1Last Post: 05-05-2009, 09:24 PM
