Results 1 to 14 of 14
    Apr 2020
    Kentucky
    Merc Promax Issue og
    Jus bought a 1991 Bullet 21VEE thatís Got a 2000 Mercury 225 Promax on it. Boat was running fine and out of the blue it cut back to only about 4600 Rpm max. Wonít get on plane unless you run someone to the front of the boat. Once on plane max 4600 rpm then all of a sudden run perfect for a half mile or so then cut back to low power. When it is running right you can stop and get back on plane normal and run good then all of sudden back to low power. Run good then bog run good then bog. Only thing I did before the issue was change plugs. Went from BUHW to BR9HS gapped on 40. Figured Plugs should b changed for jus to know they were fresh. In neutral engine will rev up fine coughs a lil as it is decelerating but revs fine. Just under load the issue of not accelerating is happening. Any help is appreciated. I know Jay Smith and Chris Carson are a Promax guru well any outboard guru I should say hopefully them or someone like them sees this post. Thanks in advance
    Jul 2002
    FT WORTH, TEXAS
    they are most likely too cold
    Jul 2002
    FT WORTH, TEXAS
    try BR8HS
    Apr 2020
    Kentucky
    Quote Originally Posted by TEXAS20225 View Post
    try BR8HS
    Had the BU8H in it not sure if they are hotter or colder but did it with them too. Wanted the BR8HS but local shop didn’t have em
    Apr 2020
    Kentucky
    try BR8HS
    Had the BU8H in it not sure if they are hotter or closer but did it with them too
    TX......somewhere?
    its NOT plugs... tha bu8h's or buhw's should run jus as good as any.. what it does in neutral and/or ona hose will never be same as under a load.... sounds more like a switch box?.. maybe droppin' a cly. or two for whatever reason?...... but we're settin' here ona computer so..........................................................................
  7. Thanks silverbullet02 thanked for this post
    FL / NY
    Check your plug wires for good tight connections or damage.
  9. Likes Dave Strong liked this post
    Think you answered your own question stating the issue started after plug change. Never know box could have been dropped during shipping making the plugs an issue. As Bobby said try a set of BR8HS and see what happens. Also as Tux stated the steel connector that clips on the top of the plug inside the boot can get loose. You should feel a positive snap as they clip on the top of the plug, if they are loose you can get strange things going on at different rpm.
    Western Pennsylvania
    Have seen some chat about amazon plugs are counterfeit china knock offs. If purchased there?
    http://www.stvowners.com
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Apr 2020
    Kentucky
    Did it with the old plugs too tried changing back
    Run it in the dark, mist the wires with a spray bottle of water if you have a spark leak it will show up.
  14. #12
    Apr 2020
    Kentucky
    Quote Originally Posted by Euroski View Post
    Bought the plugs from Advance Auto Parts they had them in stock
  15. #13
    Jul 2002
    FT WORTH, TEXAS
    weird it started when you changed plugs
  16. #14
    Apr 2020
    Kentucky
    Still chasing the issue waiting on a DVA adaptor to come in the check the issue further
  1. Mercury Tech: 225 ProMax issue
    By sv10001975 in forum Technical Discussion
    Last Post: 05-18-2019, 07:46 PM
  2. Full throttle issue. 225 promax.
    By madtunnel in forum Technical Discussion
    Last Post: 10-03-2018, 09:38 AM
  3. Mercury Tech: 2.5 225 Promax Fuse issue
    By Hydro-Peep in forum Technical Discussion
    Last Post: 05-04-2017, 09:31 AM
  4. Promax 225 cutoff issue!
    By drjerry1st in forum Technical Discussion
    Last Post: 03-14-2012, 04:40 PM
  5. 300 promax starting issue?
    By billyindex in forum Technical Discussion
    Last Post: 07-14-2007, 08:44 PM
