Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Sep 2017
    Ashland city tn
    I agree with the above , ur still to deep. U gotta get the bottom of the case on top of the water at full speed , u just added more drag with the cone cause its still under the water , that's bout only good explanation unless u lost a cyl
  2. Thanks phillnjack thanked for this post
    Likes phillnjack liked this post
  3. #17
    Lake Coochiching, Ontario
    Submerged the coned gear case has more drag = slower. If he needs the motor low to carry the bow, then the cone isn’t going to help.
  4. #18
    Feb 2011
    HUDSON, FLORIDA
    JUST an fyi, you say a chopper doesnt work for you? thats a sure clue the motor is low. choppers are horrible when too low. they are king for bow lift or a scorpion thru-hub. are you sure the cone is exactly in line with propshaft? some use a laser/ level jig, just brainstormin..
  5. Likes phillnjack liked this post
  6. #19
    South Africa
    Quote Originally Posted by Ttl View Post
    i do have a hydraulic jackplate. I’ve just modified my nose cone and hoping it will reduce drag.
    i think I will drill some vent holes in my promax to gain better hole shot.
    a chopper is crap on my boat and don’t work for me
    Last year I had some 5 or 6 older Promaxes (no vent holes) re-bored to accept the Mercury vent plug kit.
    Happy clients - but I was too occupied with personal things to take qualitative numbers.
    Trophy and Mazco also good results.
  1. Nose cone
    By TEXAS20225 in forum Technical Discussion
    Last Post: 09-25-2008, 08:08 PM
  2. bob's nose cone
    By 98BULLET in forum Technical Discussion
    Last Post: 12-02-2007, 02:56 PM
  3. prop shaft centerline to nose cone center linr
    By Wan2BFast in forum Technical Discussion
    Last Post: 04-19-2005, 11:04 PM
