Results 31 to 36 of 36
05-15-2020, 07:38 PM #31
Agree with Dave, more than likely low side of stator bad that’s feeding the switchbox on left bank. Just as you switched the boxes with no change, now just switch the sets of stator wires from box to box, so the power supplies are switched. If it switches to right bank, wallah bad stator
05-15-2020, 10:22 PM #32Member
- Jul 2006
- Karrebaeksminde, Denmark
- 38
- 49
- 49
Thanks, that makes sense. I´ll try that
Bimmer1
05-28-2020, 03:34 PM #33Member
- Jul 2006
- 38
- 49
- 49
Switched the stator wires today from one box to the other and that meant that now the right bank has no spark. So the conclusion: Bad stator (thanks Dave). I took the stator the older "parts motor" and replaced the Bad stator. That gave the engine alot more life but I still have more spark on the one bank than the other. Just an old stator or?
When trying to find the correct stator I get a little confused here: http://www.marineengine.com/parts/me...ignition-coils
There are 3 different stators, which one to buy? 398-5454A 7 , 398-5454A 32 or 398-5454A 35?
Bimmer1
05-28-2020, 09:20 PM #34Junior Member
- Feb 2020
- Paris, TN
- 20
I personally have diagnosed stators and switch boxes with nothing more than a #2phillips screwdriver arcing from plug wire to block
Still don't own a dva meter.
Jerry Snieder in New Albany Indiana taught me that almost 25 years ago.
Ive ran an 87 XR2 for years and years, it's had a few stators in it's time. Put new one straight on out of the box, she will go bad just laying on the bench...haha
06-01-2020, 07:11 PM #35Member
- Jun 2020
- east coast
- 40
- 14
- 10
[QUOTE=Merc 2.5;3206468]I'm with capt. Squeeze bulb make sure it's not puking,
Would this indicate leaky float bowl needles & seats?
06-01-2020, 08:10 PM #36
Yes usually stuck float ,trash ,bad needle or seat
Mercury 200xri Rough In-Gear Idle
By Hess in forum Technical DiscussionReplies: 0Last Post: 05-29-2019, 10:49 PM -
Low / rough idle in gear
By Blown Up in forum Technical DiscussionReplies: 0Last Post: 07-27-2012, 03:10 PM -
1973 evinrude 85 is running rough at idle speed in gear.
By Palmtreeguy in forum Technical DiscussionReplies: 6Last Post: 06-06-2012, 12:40 AM -
OMC Tech: OMC rough idle when dropped in gear
By LSaupe in forum Technical DiscussionReplies: 8Last Post: 06-20-2009, 09:43 AM -
Merc V200 Crappy Idle
By pop_r_master in forum Technical DiscussionReplies: 8Last Post: 04-27-2005, 10:49 AM
